power locks only work when car is started.
Alright, I had my battery die in my 2000 tl a few weeks ago and have been faxing a ton of issues. but this one i can't seem to fix. When the car is running the power door locks work fine. the switches work on all 4 doors. when the car is off none of the switches work and i have to individually lock or unlock each door. pain in the ass . any ideas?
Does the "keyless entry" fob work ? How about when you put the main key into the driver's
side door lock.....does it energize all 4 door locks to work ?
Recheck all battery cable wiring connections, especially the ground.
Check fuse #9(7.5a) located in the driver's side fuse panel, fuse #13(7.5a) and fuse #6(20a) in the passenger panel. There's a relay also.
Sorry I never got back to this. In case anyone has the same issue I was referring to using the switch by the door handle. Turned out the problem was a burned out fuse. I don't remember which one it was. I think radio or something. It was also causing the dome light to not work, and the doors should all lock when you manually. Koch the driver's door
The following 4 users liked this post by laid67:
^^^ Thanks for checking back in with the solution.
tman570
06-11-2019 07:56 AM
Oakes
Wash & Wax
10-12-2015 11:17 AM
