Please Help With My Tranny Problem!
Old Jan 17, 2008 | 05:40 AM
VNP's Avatar
VNP
7th Gear
Hey guys!
I have just bought an used 1999 TL off a private sell. Everything is great about the car. But im starting to think that the tranny is going to die really soon. Because when I step on the gas peddle. The car would have "jerky" acceleration and when I shift from Parking to Reverse the car would just "shake". Soo im guessing that the tranny is going to blow soon?
How much is it going to cost to fix my tranny?
and I heard there are some others in the posts where they were going to swap it for a 6 speed? Can someone please help me with this. Im really scared that it will die one day when im out on the road. And i need to know if I have enough money for a new tranny too. T_T
Thanks,
VNP (22 and broke)
Old Jan 17, 2008 | 07:39 AM
fsttyms1's Avatar
some more info would help. How many miles? If you dont have a problem with it actually shifting between gears it may just be your motor mounts. (as they have caused symptoms like that)
If your not that far over the mileage limit you may be able to get acura to good will part of the trans to make things cheaper.
Old Jan 17, 2008 | 08:20 AM
VNP's Avatar
VNP
7th Gear
wow, thanks for the quick reply. It has 250,000 km. But the trans is going to die i think. It shifts fine but sometimes when you dont warm up the car in the morning the shifting can be a lil hard. But not too noticeable. Just the major "jerking" when I accelerate the car and the lil jerk and delay when I put the car to reverse.
How much will it cost me to fix the mortor mounts?
or how much will it cost me to fix the tranny (if that broken, i doubt acura will do it out of "goodwill")
Old Jan 17, 2008 | 11:40 AM
fsttyms1's Avatar
mounts you can replace yourself for about 200 or less for them.
If its the trans it will cost 3500 and up
Old Jan 17, 2008 | 11:56 AM
01tl4tl's Avatar
Sounds like the computer warm up program is working when cold- it holds 1st nd 2nd longer revs and may feel jerky for a few minutes. Thats to get the engine warm faster so it can switch to lean running mode- not full rich warmup
Check the motor mounts- fsttyms is our Guru and knows these cars really well
get a free owner manual here- should help you alot
https://techinfo.honda.com/rjanisis/...01_OMANUAL.asp
If you have a USA car- register here
https://www.ahm-ownerlink.com/login.asp?brand=acura
Old Jan 17, 2008 | 08:45 PM
Gfaze's Avatar
S E L L
Almost 100% sure that it's the motor mounts. Sounds like they're really bad too. Get those replaced first before you do anything with the transmission.
Old Jan 22, 2008 | 11:10 AM
VNP's Avatar
VNP
7th Gear
Thanks a lot guys, I took it to the mech. and he said it was the motor mounts. After reading around, I heard its rare for the 99 TL to have tranny problems right?
Old Jan 22, 2008 | 11:22 AM
01tl4tl's Avatar
the 4 speed automatics were reliable- the switch to 5 speed and the issues began or worsened. If yours has lasted this long - its fine, Just replace the motor mounts and the car will be like new
Old Jan 22, 2008 | 12:20 PM
fsttyms1's Avatar
Old Jan 23, 2008 | 07:38 AM
Luke7's Avatar
WNC Real Estate Sales99TL
I just replaced my motor mounts-front and pass. side. Made a world of difference in engine/tranny smoothness. Easy fix.
Old Jan 24, 2008 | 10:23 AM
VNP's Avatar
VNP
7th Gear
How much does it cost to replace them? Oh man im scared cause the mechanic said the engine would fall right off if i don't replace them soon
Old Jan 24, 2008 | 10:29 AM
01tl4tl's Avatar
The front mount is about $100 at online acura dealers and $120-130 at your local dealer
The passenger side mount is about $30
Your tech should have said which ones you need.
Most often is just front, but the side and even a trans mount can also have broken while taking up the slack- as it were
There is a total of 5 motor mount and trans mounts
Old Jan 24, 2008 | 10:31 AM
01tl4tl's Avatar
thats a parts price for the mount-
front labor with trans removed .3 hr
with trans installed 3 hr
DIY 1.5 hr
Old Jan 25, 2008 | 12:22 PM
VNP's Avatar
VNP
7th Gear
But, my engine wouldnt fall off would it? im scared that my engine would fall off T_T
Old Jan 25, 2008 | 12:44 PM
01tl4tl's Avatar
If the mounts are broken thru- its being held in by stressing the other mounts and is not sitting correct position- that stresses other parts
Go to the dealer and buy them right now, ask for a 10 percent discount, and you will put their name on acurazine as good people~
Not really hard to install- just takes a little time
Old Jan 25, 2008 | 12:46 PM
01tl4tl's Avatar
And its more fall OUT than... Off.
They assemble these cars from underneath,
thats why nothing is reachable from the top... with all the layers of your skin remaining at the end of the job.
Pham Alvan
May 18, 2021 06:48 AM
SidhuSaaB
May 30, 2020 12:40 AM
Pham Alvan
Mar 16, 2016 09:17 AM
12vancover
Oct 16, 2015 12:04 PM
Matthew Purpura
Sep 25, 2015 06:10 PM
