Parking lights/ dash light/ brake light HELP!!
When I turn on my parking lights nothing happens... No lights come on inside or outside the car, but when I turn on the head lights they'll come on normally.
I've checked all the fuses and they are still good. Also I still have my stock radio in so it's not any of the wires behind there grounding out.
If anyone has experienced anything like this plz share some info thanks!!
Hey Aznboyz1223,
so when ya turn the light's stalk switch to the first position for the parking lamps....nothing at all works ?
And when ya fully turn the switch to the headlamps on position.....only they come on ?
Or do the the rear tail lamps, side marker lamps, and interior lights all work along with the headlamps ?
Could be either the stalk switch or maybe the multiplex control system.
Hey Aznboyz1223,
I actually just checked all the fuses again and it's the "small light" fuse that was out. But after I replaced it, it just blew again. I searched up on here and most ppl are havin this problem because of aftermarket head unit.... But mine is stock!!!
Is your rear brake lights out also ? So, all ya really have are the headlamps. Nothing else works at all, is that correct ? Are your dash brake warning lamps on ? Do the turn signals work ?
My guess is that ya have a short or bad ground somewhere within the system. Doublecheck all the fuses and relays. You may also want to check for continuity at the stalk switch's terminals when it's on the parking light position. Worth a shot !!!
Hey Aznboyz1223, when checking fuses....look at #47 (20a) and #59 (15a) up front in the underhood box. If ok, then check #13 (7.5a) in the passenger's side box and also #9 (7.5a) in the driver's side box.
If by chance one is blown for whatever reason, then ya gotta check that particular circuit involved if the fuse blows again. Hate the 'lil electrical gremlins....have ya done anything recently to stir up their appetite ??? Aye.
mada51589
05-03-2022 08:54 PM
