parking brake
Old 08-31-2014, 06:17 PM
jbru95's Avatar
parking brake
does anyone know how to adjust the parking break?
thanks
Old 08-31-2014, 08:56 PM
01tl4tl's Avatar
Received 1,137 Likes on 1,067 Posts
the park brakes are a small set of drum brakes hidden inside the rear rotor- that extended part that sticks out
remove wheel
On the hub of rotor is a rubber plug covering the adjustment port- remove it
rotate rotor till hole is on the bottom/6 o'clock position and look inside to see the star wheel- same as every drum brake from your youth, tighten till wheel doesn't turn by hand
Then release/push up holder clip and back down/undo 6 clicks- done
or
tighten till slight drag is heard during rotation of rotor by hand
close enough!
install wheel and torque lugs to 80 foot pounds
if never inspected, its good to remove the rotor and clean and lube the brake adjuster system- blow the dust out it
Old 08-31-2014, 09:00 PM
01tl4tl's Avatar
as long as you are in there with the wheel off:
Its probably time to flush the brake fluid system, every year is best- every 3 years is MAX between full system fluid change/flush
makes a difference in pedal feel and brake operation plus protects the brake system parts, gets very expensive when old fluid rots away seals on calipers....
Old 09-01-2014, 07:12 PM
jbru95's Avatar
now i have a problem the rubber went in the rotor what do i do?
Old 09-01-2014, 07:45 PM
Skirmich's Avatar
Received 1,017 Likes on 867 Posts
^ If that happens then its time to take the drum off..
Also you can adjust the parking brake by the foot lever itself.. The manual clearly states that you should start the adjustment by the lever then if there is no more adjustment, adjust the parking shoes. When you replace the parking shoes eventually then you should reset the adjustment otherwise the parking brakes will engage like it or not...
If you look at the lever behind it you will see an adjustment nut with some green paint in it (The more you adjust the less gap there is between engagement or disengagement).
Old 09-01-2014, 09:06 PM
jbru95's Avatar
i have rotor in the back so i was just gonna pull it off. i bought the car like this. the mechanic that looked at it said the parking brake needs to be adjust
Old 09-01-2014, 09:11 PM
Skirmich's Avatar
^ Yes its a rotor but the "parking brake" is DRUM Based..
Like I said you can adjust by the parking lever inside the car.. no need to adjust the brake drum just yet.
Old 09-01-2014, 09:12 PM
jbru95's Avatar
if i left the rubber thing in there would it mess up the brakes?
Old 09-01-2014, 09:23 PM
Skirmich's Avatar
It will melt probably? since once installed the drum gets air tight the rubber thing wont fall off..
Its pretty easy to remove it once you have the Wheel off to be honest.
Remove Wheel > Remove Brake Caliper Bracket (With Caliper) > Remove 2 Philips Screws on the Drum > Remove Drum > Reverse Procedure.
Old 09-01-2014, 09:24 PM
jbru95's Avatar
i cant get the caliper off
Old 09-01-2014, 09:25 PM
jbru95's Avatar
its on there tight
Old 09-01-2014, 09:26 PM
Skirmich's Avatar
^ Don't remove it!!.. Just remove the whole thing with the Caliper Bracket as you have to remove the bracket to remove the rotor anyway.
Old 09-01-2014, 09:36 PM
jbru95's Avatar
there is two bolts on the back that are attached to the caliper bracket
Old 09-01-2014, 09:45 PM
jbru95's Avatar
never mind got it undone
Old 09-01-2014, 09:52 PM
jbru95's Avatar
now the bottom bolt a different story
Old 09-01-2014, 09:59 PM
Skirmich's Avatar
Use a break bar or brute force, It will eventually un-bolt the rears are the easiest!
Front Bracket? Not so easy haha..
Old 09-01-2014, 10:02 PM
jbru95's Avatar
aright so i got the rotor off and it looks like the drum pads are worn out
Old 09-01-2014, 10:13 PM
Skirmich's Avatar
Get replacements and install them and Bam! your good to go for another 10 years.
Old 09-01-2014, 10:21 PM
jbru95's Avatar
Here the pics
Old 09-01-2014, 10:33 PM
jbru95's Avatar
<iframe src="https://www.flickr.com/photos/126672479@N04/15113298112/in/photostream/player/" width="75" height="75" frameborder="0" allowfullscreen webkitallowfullscreen mozallowfullscreen oallowfullscreen msallowfullscreen></iframe>
Old 09-01-2014, 10:34 PM
jbru95's Avatar
[IMG]<iframe src="https://www.flickr.com/photos/126672479@N04/15113298112/in/photostream/player/" width="75" height="75" frameborder="0" allowfullscreen webkitallowfullscreen mozallowfullscreen oallowfullscreen msallowfullscreen></iframe>[/IMG]
Old 09-02-2014, 01:58 AM
Skirmich's Avatar
Pics don't work I suggest you upload them in a friendly web based photo storage like Photobucket or Flickr. Then insert the IMG/ Code in here so we can see them.
Old 09-02-2014, 08:45 AM
fsttyms1's Avatar
Received 3,063 Likes on 2,119 Posts
^ when posting, Just use the "Go Advance" instead of the quick reply, in there there there is a "manage Attachments" tab. Select that, another box opens up. Then from there choose file from computer hit upload and when done with message it will attach file automatically
01tl4tl (09-02-2014)
Old 09-02-2014, 10:25 AM
jbru95's Avatar
https://acurazine.com/forums/attachm...1&d=1409671415
Old 09-02-2014, 02:41 PM
Skirmich's Avatar
^ there is some material left.. you can probably adjust them but once they go they will scratch the drum surface so I would replace those instead..
Old 09-02-2014, 02:56 PM
01tl4tl's Avatar
there is not much there to start with and previous owner may have backed out the driveway with brake on many times, it happens
it only looks daunting, ck the diy section for all the help you need, its just drum brakes where you have to work around the axle
buy a drum brake tool/spring remover at any parts store for 10 bucks and make life easy
the ADJUSTER needs cleaning of threads, and lightly lube with brake caliper grease or deep creep or ???
Old 09-02-2014, 10:47 PM
jbru95's Avatar
i dont mess with the rotor brake those are like new. i sent my brother the picture and he is very skilled with cars. he said it was fine but to me it looks low. i took the rotor off and alot of brake dust for those shoes came down
Old 09-02-2014, 10:52 PM
Skirmich's Avatar
^ Those are indeed worn out brake shoes... Perhaps he said it was fine if you don't use much the park brake?
I would adjust them but then again I always set the Parking Brake (Live in a downhill street) so I would replace those.. its up to you.
If you only engage the parking brake 1 or 5 times in a month then your good to go with that material left. If you always set the parking brake you should replace those as the clamping force might not be adequate anymore.
Old 09-02-2014, 10:57 PM
jbru95's Avatar
that prob what he meant because where we live we dont have many hills. he said they were fine and don't ware out much
Old 09-02-2014, 10:59 PM
jbru95's Avatar
i might as well do it anyway and get it out the way. its only a $20 job right?
Old 09-03-2014, 09:45 AM
01tl4tl's Avatar
your buddy is NOT an acura TL expert is he?! obviously not or he would know the original spec and how much thinner these are than normal full size stop the car drum brakes!
Old 09-03-2014, 07:57 PM
jbru95's Avatar
nah, my brother is really good with Nissan and g35s. he knows what he doing idk why he said that.
Old 09-03-2014, 10:29 PM
01tl4tl's Avatar
few cars have our setup for park brakes, and normal old school drum brakes for stopping were much thicker
reminder to ck torque specs on all caliper and bracket bolts- they don't go on as tight as they were stuck on!!! and too tight will mess with operation
blacktsxwagon
10-27-2015 10:12 PM
lanechanger
10-13-2015 10:56 AM
2ManyHobbies
09-24-2015 09:23 PM
Brandle34
09-23-2015 07:20 PM
Quick Reply: parking brake
