P1108 BARO Circuit High Input
Old Jul 30, 2012 | 04:34 PM
JohnsonCG's Avatar
Is this a wiring issue?
I am currently running the type s auto motor with richies harness. I checked the map sensor from the engine side and the ecu side and the wire looks good. I searched but nobody has this issue haha. I'm going to try and replace it with my other engine harness
Old Aug 1, 2012 | 04:05 PM
fsttyms1's Avatar
The Baro sensor is in the ECU.
Old Aug 3, 2012 | 03:02 AM
JohnsonCG's Avatar
I swapped ecus and engine harness and I still have this code. Help is appreciated
Old Sep 6, 2012 | 11:06 AM
JohnsonCG's Avatar
http://www.j32a.com/showthread.php?t=2455
Old Sep 8, 2012 | 02:40 AM
JohnsonCG's Avatar
It turned out that the immobilizer wires (A connector) are not supposed to be there but at the E connector. I just cut the wires since I am not using the immobilizer and the idle is lower (around 400rpm) then before but it still surges. The cel is finally gone though!
When I plug in the AEM EMS the MAP sensor reads -13 atmospheric pressure regardless if the car is off when or if i unplug the map sensor. which is super strange
Now one of the map sensors reads 3V at II position (before it read high at 3.7V)
Mike Pilipenko
Mar 26, 2024 09:21 PM
navtool.com
Sponsored Sales & Group Buys
87
Jan 23, 2016 01:25 PM
navtool.com
3G MDX (2014-2020)
32
Jan 20, 2016 11:43 AM
navtool.com
31
Nov 16, 2015 08:30 PM
navtool.com
Sep 25, 2015 05:15 PM
