Overheating Problem
Old May 9, 2006 | 09:20 AM
type-s09's Avatar
13.2@ 107 on Street tires
Overheating Problem
For some reason my car (03 TL-s) is starting to overheat when sitting still. When i am sitting still for 5 minutes the thermostat will jump almost to red H. The fans sometimes do not activate unless the car is turned off. Does anyone know how to fix this? Im going to take it to acura because i think they did something when changing out my tranny...any advice on what is wrong?
Old May 9, 2006 | 10:22 AM
ITL's Avatar
ITL
I do my own work.
the thermostat on the radiator could be bad...also, check your radiator cap. A loose cap or bad seal can cause problems as well.
Did you check your coolant level?
Old May 9, 2006 | 10:34 AM
type-s09's Avatar
coolant level is fine...i think it is the thermostat...War Damn Eagle! by the way
Old May 9, 2006 | 10:40 AM
fsttyms1's Avatar
you say your fans sometimes dont come on? could be a fan switch also.
Old May 9, 2006 | 12:44 PM
type-s09's Avatar
i was thinking it was the fan switch because it sometimes does and sometimes doesnt come on. I checked the fuse but it couldnt be the fuse because they still come on when the car is turned off. How much will the fan switch be to replace?
Old May 9, 2006 | 01:03 PM
NSXNEXT's Avatar
If you are the least bit handy you can do it yourself. It's located right near the upper radiator hose.
It's about a $35 part. It's #14 bottom right corner.
Old May 9, 2006 | 01:45 PM
fsttyms1's Avatar
possibly a bad relay also. if i had my manual here with me id look to see if there was a way to test the switch
Old May 9, 2006 | 02:03 PM
acurabum's Avatar
Where is the Radiator Fan Relay located ?Any picture . Thanks
Old May 9, 2006 | 02:51 PM
ITL's Avatar
ITL
I do my own work.
War Eagle! Good luck, man.
Old May 9, 2006 | 03:59 PM
fsttyms1's Avatar
Old May 10, 2006 | 03:34 PM
acurabum's Avatar
I need to know where is the Radiator Fan Relay not the Radiator Temp switch sensor ????
Old Jun 19, 2007 | 03:16 AM
SJGiant's Avatar
3rd Gear
Did either of you figure out if it was the sensor or the relay?
I am having the exact same issue right now. With the AC on (outside temps 80+) and idle the temp jumps up near H. Start moving and it drops down right away. If I don't use the AC while driving, the fan doesn't come on, but if I drive with the AC on for about 5-10 minutes, the fan will kick on when the car is off for about 10 minutes usually.
Thanks,
J~
SidhuSaaB
May 30, 2020 12:40 AM
Fool
Mar 10, 2016 08:42 PM
12vancover
Oct 16, 2015 12:04 PM
Matthew Purpura
Sep 25, 2015 06:10 PM
MikeJM310
Sep 24, 2015 07:24 PM
