Oil pump?
Moe T
Oil pump?
So took my car in for an oil change to the stealership, too cold to do it myself. Anyway during inspection they said I need motor mounts and an oil pump. Now not worried about the motor mounts as I can do that myself. But how about the oil pump? Where is it located? Difficult job to do? I'm waiting right now for these guys to give me their outrageous price quote. I'll update soon
have to drop the subframe and then oil pan, finally the oil pump
lots of labor
What did they base this on? ckd actual oil pressure with live scanner or installed external guage?
Or your oil hadnt been changed in a year and was bad news?
Any noise from engine,,knocking ?
you can replace the entire engine for less than they want!
IF you have a real oil pump/low pressure issue its screwed up many parts inside
toss that thing in the recycle pile
lots of labor
naw--just wait for them to call with the price-
said it might need a camfibrillator and center muffler bearings too
they wouldnt bs me would they?
Moe T
supposedly the oil pump is leaking oil??? i dont see any oil on the ground after ive parked for a while. im going to get a second opinion from another shop. how would i know if my oil pressure was low? would the oil light come on? i didnt know of this problem till they told me. i got oil chage in July and then the car was hit in september and i got it out 2 weeks ago and went and got the oil changed
I dont believe the oil pump is located inside the oilpan. I thought it should be above where the oil filter is. Otherwise how could there be oil pump leak if it was inside the oilpan. Here is the part diagram. I think it is right behind the crankshaft pulley. If you look at the seals kit, there are about 3 to 4 seals.
http://www.acuraautomotiveparts.org/...s=&view=normal
Doh! you got me,,,at least the year is almost over and my mistake count resets
So used to thinking of oil pickup tube inside oil pan- pan gets hit and pickup damaged...
The oil pump does appear to be on the front of the engine, like it belongs,, and is located on most every car I have ever worked on, duuuuuh
Where they could trace a leak to it--may remove a cover to see clearly,
or know that ~if oil drips here it always came from there~
If true its important
Are you due for a 105 tbelt service?
Gurus of engine externals: HELP!
What does the OP need to do for access and replacement?,,guessing a 105s labor + some pump r&r labor and the absurd cost for pump itself, plus motor mount w/trans installed , a few hours for that,,, = 1700
do they have a weep hole-- similar to water pump, to indicate internal seal or shaft bearing failure?
Original Owner / Oct 1998
I wouldn't do anything unless the pump housing is leaking oil. (Ours is)
The gasket/screen costs only a few dollars from Acura, I just bought one but have not yet installed it. Two bolts (near the oil filter) to access it.
Yeah, for sure get a second opinion if you do not have any drips.
IBankMouse
06-13-2020 12:53 PM
