Oil pan spec?
Old Mar 29, 2013 | 10:26 AM
BobyB's Avatar
8th Gear
Oil pan spec?
Does anyone know the torque specs and pattern on our oil pans?
Old Mar 29, 2013 | 05:34 PM
assclown's Avatar
2000 acura tl FPR
3.2TLc's Avatar
As above ^^^ , 12 N-m (1.2 kgf-m) or 8.7 lbf-ft.
Start with the middle of the pan's length, then criss-cross working outwards alternating from left to right, then finally the ends back and forth.
Old Mar 29, 2013 | 07:59 PM
MilwaukeeDave's Avatar
I don't gotta do this yet but to clarify does that say put the Hondabond on the oil pan, engine, and inside the bolt holes??
Old Mar 29, 2013 | 08:06 PM
assclown's Avatar
2000 acura tl FPR
I didn't, I just put it on the oil pan and engine mating surfaces. I also didn't use hondabond, I used an RTV, can't remember what color though.
Old Mar 29, 2013 | 08:30 PM
3.2TLc's Avatar
Thumbs up Hondabond liquid gasket sealer....
Yeah, I have yet the need to do this.....but it appears that the sealant only needs to be applied to the underneath of the motor's mating surface for the oil pan. It also recommends putting the sealant into the bot holes.
The last time I did an oil pan was on my son's '99 Durango, it along with the tranny pan were badly rusted. The RTV sealant worked really well along with new retaining bolts. Just make sure that everything is really clean.
Old Apr 1, 2013 | 10:38 AM
BobyB's Avatar
8th Gear
Appreciate all the help yall!
IBankMouse
Jun 13, 2020 12:53 PM
Specmiata82
Sep 30, 2015 10:04 AM
AcuraKidd
Sep 25, 2015 11:18 PM
STL TL-S
Sep 23, 2015 08:52 PM
4drviper
Sep 23, 2015 07:42 PM
