Oil Pan Removal
Old Jan 13, 2007 | 11:36 PM
MurkyRiversTL's Avatar
COTM Coordinator
Oil Pan Removal
So on Wednesday I finally decided to find the source of my oil leak (its been happening for a couple of days) I went under the car and noticed that it was coming from the where the oil pan mounts to the block.
I thought it was going to be pretty easy but, boy was I wrong. At first I thought that I could undo all the bolts and slide it over the exhuast pipe. Of course I was wrong.
So I had to unbolt the exhaust pipe frpm the headers. And tried pulling it down. And of course that wasn't enough.
So I had to unbolt the o2 sensor, and that still wasn't enough. I pulled and tugged to get it down enough and finally it worked.
Then I scraped off all the old sealant on the oil pan and the block. I then used a high temperature silicone to reseal then put it back on. Such a pain in the ass.
I hope that you guys dont have to do this, but if it does just remember all the shit that comes along with it.
I started working on it at 530 and didn't fiish until 130 in the morning.
Old Jan 15, 2007 | 11:51 AM
fsttyms1's Avatar
Yea its a pain due to having to remove the down pipe to get it off. should have used honda bond though for the oil pan gasket
Old Jan 15, 2007 | 11:57 AM
COTM Coordinator
What is the difference? I talked to the guy at the dealership and he said that using a high temp silicone or RTV would be just as good as what they use. Is it because it was made specifically for that part or something. I'm pretty sure it will be fine I haven't had a leak since I did that.
Old Jan 15, 2007 | 12:39 PM
fsttyms1's Avatar
Im sure it will be fine, but honda bond is referd to as the best
Old Jan 16, 2007 | 09:34 AM
honda_inspire99's Avatar
Skeet Skeet Skeet
like he said honda bond is the best. The oil pan is not hard to get off just take your time....use honda bond they are almost half the price at the honda dealership
foxriderar77
Nov 19, 2020 10:17 AM
kmarqueling
Oct 3, 2015 01:14 AM
Aleax
Sep 11, 2015 11:31 AM
Allen_442
Sep 8, 2015 06:01 PM
