oil pan puncture
technically, you're supposed to clean the pan clean of ANY oil...which means removing it.
the jb weld wont adhere if there's any slick oil coming from the puncture.
i google searched and someone said to use a stick epoxy instead of the JB weld. but that also assumes a clean oil free pan
Clean the bottom of the oil pan > Cut open an aluminum can to get a sheet of metal > Cover it in gasketmaker, and stick it to the bottom of the pan > Hold it till it sets, then use some jb weld or epoxy stick to glue the edges to the pan.
probably won't work but if you're dedicated to fixing this the wrong way, it's worth a shot lol
