Oil Leak???
Old Oct 29, 2007 | 07:35 PM
jgaiser00's Avatar
9th Gear
Oil Leak???
2001 TL with 185k, it has an obvious engine oil leak from between the engine and trans. Am I correct in assuming that it would be the "rear main seal"? Has anyone else had this problem? What did it cost to be fixed? Please help I need my old reliable back. Thanks
Old Oct 29, 2007 | 07:58 PM
01tl4tl's Avatar
first you need to remove the inspection panel under the car
Look inside and see if its coming from the trans- reddish fluid
OR the engine rear main seal- engine oil
Either way its critical you get it fixed
Requires removal of tranmission- about 4 hours for a good tech and a 10$ part
Old Oct 29, 2007 | 08:17 PM
jgaiser00's Avatar
9th Gear
I have already removed the inspection cover and it is engine oil. The part is about $17 dollars at the local auto parts store. I am a certified GM tech. I simply wanted other experiances since this is not a car i work on every day. There is a reason that I work for GM but drive a Forgin car, it rarely needs worked on thats what i love about it.
Old Oct 29, 2007 | 08:44 PM
01tl4tl's Avatar
It's like any other front wheel drive car- just rip it out- pop in a new seal- slap the trans back in and done
Old Oct 30, 2007 | 06:34 AM
jgaiser00's Avatar
9th Gear
perfect, thats the plan. thanks
Old Oct 31, 2007 | 08:42 PM
fsttyms1's Avatar
It requires the trans to come out, about a 4-5 hr job complete turn around on the TL. A few have had the problem. Most notably on then 03s
Mike734
Dec 10, 2021 01:25 PM
IBankMouse
Jun 13, 2020 12:53 PM
spudweb
May 22, 2016 02:39 PM
Avenger411
Oct 11, 2015 03:53 PM
Boraxo
1/2G MDX (2001-2013)
Sep 29, 2015 04:35 PM
