O-ring power steering pump location?
Old Apr 28, 2014 | 03:06 PM
Fanatic's Avatar
Hi friends, i'm looking for hose that has the oring, is not in the water pump but probably in the hose.
Can you tell me where is it? i saw a youtube video, but the guy unscrewed below the hose, and i can't find that on my TL 1999
Old Apr 29, 2014 | 11:29 AM
acutee's Avatar
Power Steering O-ring replacement
At the bottom of the reservoir there is a thicker tube that connects back up to the ps pump on the right side. There is a little screw underneath holding the connector onto the pump. Take the screw out (10mm), remove connector, then remove the o-ring. Place the new o-ring on the connector and insert back into the ps pump and replace screw. You may want to remove the return pump tubing from the connector but make sure you have a rag underneath or your belts will be covered with fluid. Also it was easier for me to remove the wiring harness clips that's are near the ps pump. Of course grap some more ps fluid as you'll most likely lose a little in the process. Good luck.
Old Apr 30, 2014 | 08:59 AM
Fanatic's Avatar
Thanks acutee!
Old May 1, 2014 | 10:39 AM
acutee's Avatar
Glad I could help. The screw is hidden (the first image) underneath the L connector that it is hard to see.
Originally Posted by Fanatic
Thanks acutee!
Old May 11, 2014 | 07:18 AM
Luke7's Avatar
WNC Real Estate Sales99TL
I bumbed that line going into the power steering pump and it started sucking air into the system. Had to replace the O ring also. Of course the Acura garage ripped me off for $3 for an O ring. Go Figure.
Old May 24, 2014 | 08:29 PM
notnac's Avatar
After a timing belt change on my '99 TL, started hearing whining noises. Honda shop wanted to sell me a new PS pump. I've read the messages hear about the inlet o-ring being at fault and bought the part and want to do the job myself.
The bolt that I need to remove is in a very tight place. Could someone offer suggestions on how to remove and what tools to use? I noticed that on later year's models, it's doesn't look as tight as on my '99. Thanks!
Old May 24, 2014 | 08:41 PM
TLZINE99's Avatar
U need to use a U-joint to get to that tight area.
Old May 25, 2014 | 02:47 AM
notnac's Avatar
Yeah, you would think that would work. There's a video of someone making this repair on a 2005 (?) TL using a universal joint. I tried a universal 10mm socket and its still tight.
Anyone who has made this repair on a '99 TL??
Old May 25, 2014 | 10:08 AM
TLZINE99's Avatar
if its still tight, just remove the powersteering pump.
Old Mar 13, 2015 | 10:44 AM
MS225's Avatar
Instead of making a new post i will just ask in here.
My powersteering pump is whining but i have no issues with steering.I see its leaking out close to the reservoir and when i add fluid(fill it over recommended) the whining goes away temperately.Is this pointing at o-rings or damaged line?
TL-Rocket
Apr 29, 2023 02:33 AM
Yikes
May 3, 2021 04:29 PM
mike from annapolis
May 7, 2017 08:21 PM
asahrts
Sep 4, 2015 05:55 PM
