Noise from Front Driver Side
Old Mar 16, 2010 | 02:44 PM
SLaMMeD TL's Avatar
SOHC V-TEC
Okay, i have been trying to figure this out for a while now i hope that someone knows what it could be any help could and would be helpfull... I have a 2003 TL (base model) and i am hearing a weird noise from the front driver side of the wheel i have just replaced the rotors and pads BRAND NEW no other side of the car makes this noise except the front driver. I am lowered on F2F got about 5k on them. Its been allingned/balanced not too long ago, about 3-5K miles ago. front passanger tie rod was replaced when suspension was put on. Does anyone know what could be causing this noise (squeeking, grinding, etc.) i am almost CERTAIN its not the brakes, it only makes the noise when slowing down like a bushing/mount is messed up and the weight of the engine is making something grind together? Please someone help!
Old Mar 16, 2010 | 03:48 PM
chao_zu55's Avatar
have you checked your wheel bearings?
Old Mar 16, 2010 | 04:53 PM
fsttyms1's Avatar
If your positive its not the brakes, its a good bet its the bearing.
Old Mar 16, 2010 | 08:32 PM
SLaMMeD TL's Avatar
SOHC V-TEC
I thought if its the wheel bearing it would make a noise when the car is accelerating not decelerating? I mean there is no shaking or vibration coming from the wheel when braking so i am guessing not the allingment or balance? Yea and i am 99% sure its not the brakes they are brand new and i have checked the pads 2x and they are wearing evenly and no weird or uneven wear also the rotors are smooth and even when felt with hand.
Old Aug 2, 2010 | 06:39 PM
TL45's Avatar
I'm pretty sure it's your wheel bearing. I am having that problem and it sucks. It's hard to change the hub/bearing but possible.
csmeance
Jan 7, 2026 06:25 PM
nanos
Nov 12, 2015 08:41 PM
Ny1718
Sep 11, 2015 09:21 AM
JnC
Sep 11, 2015 06:06 AM
08 NBP TL
Sep 8, 2015 08:49 PM
