No Shift Gate Glow/Light HELP?
Old Apr 29, 2012 | 10:30 AM
tjkazai's Avatar
2002 Acura TL
What the hell?
It's so hard to see without the glow/light on the PRNDL/Shift Gate..
Only way to figure it out is to check the dash, anyone know if this is a fuse or electrical problem? Can someone tell me what fuse box it's located at? Drivers or Passenger or under the hood? and What number the Fuse is? If it's an electrical problem what do I do?
Please help, I'd really appreciate it!
Thanks so much!
Old Apr 29, 2012 | 11:36 AM
fsttyms1's Avatar
The bulb is most likely burned out. Pull the grey/sliver trim off, then pop the shift plate cover off (the goofy notched black plastic one for the shifter). grab a needle nose pliers and pull the bulb out and replace. Just go to the dealer for it.
Old Apr 29, 2012 | 12:52 PM
tjkazai's Avatar
2002 Acura TL
t
No but sometimes it goes back on.. on random days,
do you know where the fusebox is for this and what number it is? and I'll check that if not it's probably the bulb, theres no DIY on how to remove the bulb is there
And how do you remove all that disgusting gunk, dirt, inside the shifter? it's gross... Is there a spray I can buy or what should I use to remove like home made ingredients ?
Old Apr 29, 2012 | 09:03 PM
dreem1er's Avatar
deal with it
bulb/connection maybe loose, at worst the cable is bad, you can do what i did...i cut the stock cable put a led...you can get the set up from the door handle led diy...then wire up the led to the original cable and problem solved, i put a blue led in there
dreem1er's Avatar
deal with it
a mixture of this awesome substance called soap-n-water in combination with the use of a rag ftw
Old Apr 30, 2012 | 10:39 AM
fsttyms1's Avatar
t
Its NOT a fuse. There isnt just 1 fuse for that bulb. I told you how to remove the bulb. The directions cant be any easier than what i posted. Just pop the trim pieces off, take needle nose pliers and pull bulb out.
Old Apr 30, 2012 | 03:07 PM
dreem1er's Avatar
deal with it
Ooooo feeling testy Kris? Someone needs a
Old Aug 3, 2013 | 02:20 PM
tjkazai's Avatar
2002 Acura TL
till this day I still haven't done it hahahah, where can I buy this type of bulb?
Old Aug 3, 2013 | 03:46 PM
MilwaukeeDave's Avatar
He answered that back a year ago.
SidhuSaaB
May 30, 2020 12:40 AM
Jul 16, 2017 07:33 AM
Skirmich
Oct 1, 2015 12:59 PM
