No Power To Radio??
Old Feb 1, 2015 | 11:31 PM
wapa301863's Avatar
3rd Gear
No Power To Radio??
So today I was attempting to install and aftermarket amp, and subs but sadly failed. While I was in the backseat connecting wires, and what not the radio shut off. I guess I must have touched the wrong wires, or maybe it was something else, I don't know. I turned my car on and off, and pushed buttons on the radio but nothing, no display, no lights, and no power to the cigarette lighter. I checked the fuses that had to do with ACC or navigation on both driver and passenger side, and under the hood but they all appeared to be intact. I read that if I hold 1 and 6 on the radio it might turn on. Would that work in my situation?
Old Feb 2, 2015 | 02:05 PM
fsttyms1's Avatar
did you check your clock backup fuse passenger side dash fuse panel?
Old Feb 5, 2015 | 11:08 AM
01tl4tl's Avatar
do as above poster says- he is the guru of gen2!
fuses cover many items or areas= and does not list each on the cover
example the CLOCK fuse is secret backup power to the ECU engine control unit!
pass side fuse panel is on end of dash or lower kick panel
the radio 1 and 6 buttons trick is to recover the radio security code=on some years
Jul 16, 2017 07:33 AM
Puma Jim
20
Oct 20, 2016 11:59 AM
SinCityTLX
20
Oct 19, 2015 11:23 AM
jdmaszfcuk
Oct 19, 2015 12:31 AM
