No Heat
I=X - optomos
No Heat
Its blowing cold/cool @ 90 degree setting. I havnt had time to diagnose yet, but wondered if anyone else had this problem before and knows what it is.
I hope its not the heater core
Skeet Skeet Skeet
I=X - optomos
Originally Posted by honda_inspire99
mine blow hot even at 60 degrees now it doesn't it work at all
I looked at the fuses on drivers side and under the hood. Now I need to test the heat blower relay under the hood and check if the heater core is not plugged. It sucks having a problem that not many people have run into.
also may be the actual dash temp control.
I=X - optomos
I found out what my problem is. It is the "control valve" aka "heater valve".
You can see the picture of the part **HERE**
It's $50 at the dealer or you can get it for $29 **HERE**
So if you have no heat, it's still blowing air, you don't have water on the passenger side floor or condensation on your windshield, look at this first.
Fsttyms, I think you are right about the temp control being inspire99's problem.
Cool that you found it.!
I=X - optomos
Here's pictures of the part
It's almost in the center of the firewall.
Satori, call the 800 number on the second web site & ask them about that part for a 01. I did see that part available for that year on their site.
Skeet Skeet Skeet
6th Gear
Thanks I'll take a look at it.
Have you switched yours out? Did it fix the problem?
I=X - optomos
Mine was stuck so I just played with it and got it to work. I ordered a new one yesterday because even though its working now it still needs to be replaced so I dont have to deal with it again. Not a big deal to replace; two clamps & hoses.
Post again if you guys get yours fixed.
6th Gear
Well I haven't ordered a new one yet but I played with it and it loosened up...seems to be working fine but I know I'll have to replace it soon.
Thanks for the help
Thanks for the help
well for grins last nite while i was in the process of getting my engine ready for removal i played with mine and mine was really hard to move (but i know mine works) so are you sure that thats the problem
I=X - optomos
I=X - optomos
Its this part that is bad
I replaced it when I did my headers. I will tell right now that the bolt that holds the bracket to the firewall was a pain to remove and it would have been a nightmare if the downpipe was still there.
