new noises
Old Oct 2, 2010 | 10:33 PM
twill220's Avatar
new noises
just discovered new noises that seem 2 b comin from power steering or steering wheel column. it seems 2 have that sound of the power steering pump. just had the timing belt and tentioners and water pump replaced with new parts in june about 3k miles ago. has anyone had this problem and what should i replace now that i've had the other work done
Old Oct 2, 2010 | 10:59 PM
01tl4tl's Avatar
chances are the ps belt tensioner was set too tight and damaged your pump doing the 105
shop is responsible for its replacement, go see the manager and tell them of new noise,,let it be diagnosed and then deal with their liabilty
shops have insurance and a slush fund because this stuff happens,,sorry but it happend to you
one reason to be sure the actual tech working on your car has done many of these TL jobs before..so they know how tight things are supposed to be
Old Oct 3, 2010 | 10:03 AM
twill220's Avatar
it wasnt done at the dealer but the mechanic is a honda tech. should i just replace the ps pump or is there something else more serious
Old Oct 3, 2010 | 11:58 AM
01tl4tl's Avatar
let the tech inspect the pump with a mechanics stethascope (everyone should buy one for 5 dollars)
if the bearings in the pump are whining or grinding you have found the problem
assuming install error (happens a LOT) He should cut you a `parts at cost` and cheap labor,, since its a labor error that made you spend more money
if thats occured I would replace the ps tensioner, belt if not new, and the pump--if belt was tight the tensioner took abuse,,replace it now and drive without concern
Old Oct 5, 2010 | 05:06 PM
TLer trash's Avatar
There have been quite a few on the third gen side who had to replace the ps pump inlet o-ring after timing belt/h2o pump work. Lately, there have been a few on this side as well.
Old Oct 6, 2010 | 10:32 AM
steeze4twenty@hotmail.com's Avatar
power steering fluid topped up?
MrHeeltoe
20
Feb 23, 2023 01:54 PM
SexyRL
4G TL Problems & Fixes
Aug 19, 2016 10:03 PM
xsilverhawkx
Oct 5, 2015 11:00 AM
MrHeeltoe
Sep 29, 2015 10:43 PM
MrHeeltoe
Sep 28, 2015 05:43 PM
