New brakes , good rotors, steering wheel still vibrates..?????
I just changed my brakes thinking that the reason for my steering wheel shakes were due to old worn brake. But it still vibrates when braking from a high speed.??..balanced tires and good rotors.. what could it be now? Bushings???? Somebody got some insight on this.??
When you say good rotors, did you do a run out and check with a micrometer? As cheap as rotors are these days (about $20 each from RockAuto) I'm always amazed at the people who don't replace their rotors with every brake job and then complain about noise or steering wheel vibration.
replace your rotors
I agree with y'all. Curious...has anyone had warping on a particular rotor? I seem to warp my front left more significantly than any other post. I just attributed it to buying cheap rotors, but curious if it actually has to do with relative position to the proportioning valve.
I had always believed that the continual 200 pound or so driver caused the imbalance. In the thousands of brake jobs I have done, the drivers front always had just a slight amount more of wear.
