Need to reset computer after used engine installed?
Old May 26, 2014 | 06:38 PM
JayRay's Avatar
4th Gear
Sadly, my 2003 acura tl just died. The dealership did some testing and a compression test, which kinda worked since the engine wouldn't turn over. I was told that my engine was DOA!
I found a used engine...with the price of in and the cost of installation, I cant pass it up. My question now is, do I have to get the computer reprogrammed with an engine swap??
Old May 26, 2014 | 06:49 PM
3.2TLc's Avatar
What is the donor motor coming from ?
What caused your original motor to be "DOA" ? Timing belt failure or extreme overheating ?
While I'm not 100% sure, I don't think the computer would know the difference if it was the same type of motor. If it came from a '99 or an "S" model, than maybe there would be a problem, IDK. Somebody else will chime in later to help you. IMO, the dealership should know.
Old May 26, 2014 | 06:58 PM
Skirmich's Avatar
Nope! its plug and play if its the same Engine and since you will probably unplug your battery your ECU will be already Reset so it would fire up the engine as brand new..
Old May 26, 2014 | 07:53 PM
ErickUa5's Avatar
Mr.Helpful Diagram
Perfect chance to put a Type S engine in there like I did, its also plug and play with the exception of the air filter box.
Old May 26, 2014 | 07:59 PM
Skirmich's Avatar
^ But the lower Redline
rockyboy
Aug 4, 2024 10:35 AM
Feb 25, 2020 09:57 AM
JarrettLauderdale
2G CL Dynograph Gallery
Sep 21, 2015 07:51 PM
EE4Life
Sep 11, 2015 10:13 PM
vbgregg
Sep 11, 2015 05:38 PM
