need QUICK 99 tl intake install help
Old Nov 16, 2011 | 06:52 PM
yeedatoy's Avatar
kill you till you die
Just pulled everything off in the dark not expecting there to be a mini radiator in the intake. i have the hose connected from the valve cover to the intake, but which is the other hose that connects to the intake pipe? there is a hose on the throttle body which is obviously a coolant hose, but i cant tell which of the other two hoses are what..i cant see shit!
Old Nov 16, 2011 | 08:00 PM
yeedatoy's Avatar
Never mind, found a lighter and traced the other coolant hose to the thermo housing. Who the fuck doesn't have a flash light in their house? This dumbass....battery killing flashlight android app FTL. How long does it take to get used to this annoying hissing sound?
Old Nov 16, 2011 | 08:20 PM
n1njai's Avatar
Hissing? From your coolant lines or the intake?
Old Nov 16, 2011 | 08:22 PM
yeedatoy's Avatar
Intake, and it makes quite the strange noise when I turn the car off. While driving, it makes sort of a faint hiss/whistle noise at light throttle...I also have the fog cover cut out on that side.
Old Nov 17, 2011 | 10:27 AM
01tl4tl's Avatar
ck for vac leaks
ck coolant level since the TB heater lines were disconnected
Old Nov 17, 2011 | 03:00 PM
Vman159's Avatar
I have the same hiss. From what i am told than most likely that is the air being sucked in. Its terribly loud during a cold start up.
cycdaniel
Dec 17, 2019 10:58 AM
hues10
1G RDX (2007-2012)
Sep 7, 2016 03:47 PM
james357
Feb 13, 2016 02:37 PM
nanos
Nov 12, 2015 08:41 PM
Abe_Froman
Sep 16, 2015 01:27 PM
