NEED Help! Post UR pulley install, pwr steering noise!
Help PLEASE!! Just installed the UR crank pulley (S) on my 00TLP. Used recommended gates belts (alt/ac and pwr steering). Now, the powersteering pump is a lot louder than it should be and gets even louder when turning steering wheel. My PS fluid reservoir overflowed too. I lowered the level, but still same noise. I've adjusted tension, but doesn't make a difference.
HELP!
TIA
P.S. In order to get the spin rate of the PS pulley closer to factory with the UR crank pulley, has anyone found a larger pulley to replace the PS pulley with? Could this be the answer?
HELP!
TIA
asahrts
09-04-2015 05:55 PM
