Grinding/Rubbing Noise?
Old Aug 29, 2006 | 11:06 PM
HoFF's Avatar
4th Gear
My 2001 Acura TL has recently developed a grinding/rubbing noise from what seems to be the driver's side front. I hear it at various times: When I brake, when I turn right, when I turn left and right at high speeds, when I turn to the starting position on the steering wheel at various speeds. I don't know if it is because I might have hit something like a curb (which I don't recall doing so). The sound is predominant when I touch the brakes, so I think I might need a new brake pad or drum. However, I can still hear the sound when I'm driving (mainly turning right). I want to fix this problem as soon as possible, but I don't want to throw away money on repairs that don't fix the problem. Does anybody know what is going on? Much thanks is appreciated!
Old Aug 30, 2006 | 01:50 AM
tientruong's Avatar
02' 3.2TL-s /w NAVI
When was the last time you changed your breaks?
Old Aug 30, 2006 | 02:05 AM
tim'sTLS's Avatar
you need brakes..
Old Aug 31, 2006 | 09:31 AM
HoFF's Avatar
4th Gear
What do you mean by I need new brakes? New pads or rotors or what?
Old Aug 31, 2006 | 06:30 PM
tientruong's Avatar
02' 3.2TL-s /w NAVI
Pads
Old Sep 1, 2006 | 03:02 PM
SoCalwarrior's Avatar
You should start by inspecting the brakes to see what's needed. If you Brakes went metal to metal. That meaning that your pads friction was gone and the metal was rubbing on the rotor. New rotors and pads. Good Luck!!!
Old Sep 3, 2006 | 02:10 PM
HoFF's Avatar
4th Gear
Thank you. I will figure out the problem today and will go to an auto parts store tomorrow.
MrHeeltoe
20
Feb 23, 2023 01:54 PM
SexyRL
4G TL Problems & Fixes
Aug 19, 2016 10:03 PM
xsilverhawkx
Oct 5, 2015 11:00 AM
MrHeeltoe
Sep 29, 2015 10:43 PM
MrHeeltoe
Sep 28, 2015 05:43 PM
