need help gas mileage sucks
Old Jun 21, 2007 | 08:48 PM
draco0858's Avatar
hey guys i have a 01 tl with 105,000 miles the car has cai and catback on it and well the problem with my car is when i first bought the car i would go for ever without filling her up. but now i really cant go a week in hawaii without filling her up. i get about 190 miles to the tank thats really just city miles but highway miles i get about 230. but i really noticed the difference in gas mileage now. i havnt done any major maintenace on it and the maintence required light is on i think its the 90,000 mile light thats what i have been told. some people told me it might be the o2 sensors might be bad and probably the egr might be dirty. so i would really appreciate it if you guys could help me. thanks a lot.
Old Jun 21, 2007 | 10:26 PM
Eedvl1999's Avatar
First of all do a search there is a thousand threats on gas millage.
a. make sure your tires are the correctly inflated its good to have them at 35 some prefer 38 and make sure there is no TOO much wear on the tires.
b. fix your maintenance light lol.
c. seafoam that B**ch.
d. keep your rpm under 3k when accelerating
e. turn off your ac if you can, although is better to have ac on instead windows open bcuz of the drag.
f. make sure your oil is changed along with spark plugs etc.
There is hundred of other things to increase your gas millage, these are just few of the top of my head.
Old Jun 21, 2007 | 10:38 PM
csmeance's Avatar
check the engine and cabin air filter, that will help with less engery consumption. Seafoam the car and also check the fluids for proper levels and colors. Also with 105k miles, You will need to the timing belt and other stuff soon. Check the air pressure in your tires and also get rid of any unnecessary weight such as a bag of sand in the trunk.
Old Jun 21, 2007 | 11:43 PM
draco0858's Avatar
well i do have 18's on it with coilovers and i did seafome it about a month ago but i do use the manual shift a lot thats probably another reason too. so ill try all the other stuff too. thanks a lot
Old Jun 22, 2007 | 01:05 AM
01tl4tl's Avatar
Seafoam it again, do 1 can to 1/4 tank of gas and 1 can into the intake vac line as per forum instructions
Use auto trans in D5, or D4 in traffic and hills, realize 18s are pulling a LOT of tire across the road surface and have changed the final drive gear ratio
NGK Iridium plugs will make it feel like new !!!
Old Jun 23, 2007 | 12:40 AM
bibledriver's Avatar
Something is missing...my
As long as the 18s are with the proper tire, the circumference will not change (same amount of tire to drag across the road). And if the final drive ratio did change, his odo wouldn't know it! He would just get farther than his #s say.
But, I know when I threw my headers, my mileage dropped. I think that the bit of low end power loss and the fact that I wanted to incessantly demonstrate to myself (and whoever else was around) that my car was faster and sounded better now! (see avatar) lol.
Old Jun 23, 2007 | 09:06 AM
fsttyms1's Avatar
But with 18's your adding more weight and moving the weight further out which makes a big difference.
Old Jun 23, 2007 | 11:33 AM
01tl4tl's Avatar
Show of hands please- from those who went from 16s to 18s, put sticky tires on it, and still got reasonable economy!!!
Old Jun 23, 2007 | 10:34 PM
6spMike's Avatar
Mike's Silver Bullet
Do you mean the check engine light? Fix whatever is causing that before doing anything else.
Old Jun 23, 2007 | 11:04 PM
fsttyms1's Avatar
Im still at 32mpg hwy
Old Jun 23, 2007 | 11:50 PM
Haven't moved to 18's yet, but hope to soon (from 17's anyway).
Old Jun 24, 2007 | 11:36 AM
01tl4tl's Avatar
Kris- you need to DQ yourself from all parts life and gas mileage discussions
I think your 6sp 00 tl-s runs on starlight, dreams and kitchen scraps!!!!
08KBP_VA
Oct 22, 2019 01:55 PM
xsilverhawkx
Oct 5, 2015 11:00 AM
Sarlacc
Console & Computer Gaming
Sep 30, 2015 02:15 PM
San Yasin
Sep 29, 2015 10:52 AM
jmaxima03
Sep 27, 2015 10:22 AM
