Need help diagnosing a smell problem
Today at 2:00 Am the wife was on the way to the airport to work. She was rerouted due to construction. After a mile on city streets she noted a really rank odor in the car. She thought it was the neighborhood. But after several blocks she noted it again. She stopped and looked the vehicle over, no smoke or flames. At any rate, she was afraid to continue driving so a tow truck was called.
When It arrived home, I checked for trouble codes via OBDll , none logged. Started car and it ran fine. No appearant problems. Now, she told me she shut the radio off to listen for engine/car sounds. When I turned the radio on, it was locked out on "enter code". I entered the code and the radio worked but only on the large base (I assume) speaker in the center of rear window. If the towing company had for any reason, disconnected the battery, the seat memory would have been lost as well as the time on clock. I think anyway.
Could the smell have come from the sound system (Bose 6 CD, etc) and would the system lock out if overloaded. Next question, if it did, am I looking at speakers or the CD.
Thanks for looking,
Referman
Thanks for looking,
Referman
I would first check the radio. If you dont have the door speakers working id guess the radio is the problem.
Looking at a parts blow up. It appears that there is an "equalizer" up front and an amp in the rear. I assume that could have burned up. So I am now looking at the possibility of cd unit and/or equalizer or maybe even wires.
I guess its time to start looking into it. If I can't smell the problem I am lost. I have no knowledge of sound systems and how to test.
SidhuSaaB
05-30-2020 12:40 AM
Fool
03-10-2016 08:42 PM
