Need help ASAP...(fog light mod)
Hey there, I am in process of doing the first version fog light mod as I want fogs on with parking lights.
I have everything taken apart but I am looking at grey plastic piece that the 5 wires go into, and cant figure out how to pull the two wires out of it that I need to splice together. Am I doing this right. I thought I just needed to pull the red/black wire and the white/red wire, splice them together then plug back into the "taillight" power hole.
HOW DO YOU PULL THE WIRES OUT OF THE HARNESS??? Also, once out do I just splice them togehter? How do you get them to go back into the harness???
Please help, as my dash is taken apart and I need to get this done asap. Thanks.... Spencer
did you check the DIY thread with pictures? i'm not sure what gray plastic thing with 5 wires you are talking about or which version of the mod you're doing, but i followed the DIY thread without any problems. good luck!
here is one of the DIYs I referred to above^^
Pics on page 2. This is the one I did:
https://acurazine.com/forums/2g-tl-1999-2003-98/fog-light-mod-alternate-version-549015/
i did the fog light mod, BXSCIG version, its amazing... but one problem occured after doing it... check engine and SRS light came on. I fixed the engine lite by unplugging the battery and turning n' holding the key to start position for 5 secs but the SRS stays on... Did this happened to anybody else? any input would be appreciated ...
InFaMouSLink
10-27-2015 06:51 PM
sockr1
10-01-2015 01:31 AM
oyayjoe
09-12-2015 04:40 PM
prox
5G TLX Problems & Fixes
09-01-2015 02:03 AM
