Need to clean the windshield-the registration sticker left a mess -HELP!!
Old Nov 11, 2007 | 10:58 AM
mzahidi's Avatar
Unhappy Need to clean the windshield-the registration sticker left a mess -HELP!!
Need to clean the windshield-the registration sticker-HELP!!
I had removed the old sticker and had to place a new one so now i have parts of the old sticker stuck in the bottom corner of the windsield, and the new sticker is comming off too.
its all the way in the bottom right of the windshield. so i dunno whats a good way to clean it w/o messing up my dashboard. goop????
im sure you guys got some good ideas...
stupid ny state registration stickers!
any help is appreciated.
Old Nov 11, 2007 | 01:56 PM
VeEzy's Avatar
B A N N E D
try goo gone
Old Nov 11, 2007 | 04:44 PM
acutee's Avatar
peel of the sticker first, use hair dryer to heat it up the remaining, then use packaging tape to pull it out. goo gone could do the job, but could be very messy.
Old Nov 11, 2007 | 10:29 PM
Rsoetidjo's Avatar
Rich
Originally Posted by VeEzy
try goo gone
goo gone should work.
I usually just use windex and razor blade.
Works good on glass.
Old Nov 14, 2007 | 10:42 AM
2000 TL's Avatar
Cover part of the dash with a rag, towel or newspaper below the gunk.
Spray WD-40 over the gunk on the windshield, don't have it run all over.
Wait...20 - 30 minutes.
If the gunk is real stubborn, use a razor to scrape off. Otherwise a cloth or paper towel will do. Just wipe off.
Clean glass with your preferred cleaner.
Remove dash cover from above and check for any WD-40 or glass cleaner overspray and remove.
Done.
I had an RX-7 way back that had two dried adhesive strips on the back window I could not remove. A buddy told me about the WD-40 trick and it worked perfectly. Hope it works for you too.
Old Nov 14, 2007 | 11:50 AM
02type-s's Avatar
-Arsenic-
Everyone is making it way too complicated and time consuming. Spray with glass cleaner. Scrape with razor blade with pressure. Thats it.
jblessing
Aug 8, 2018 09:43 PM
Frathora
Sep 28, 2015 11:29 PM
Dunnik
Sep 15, 2015 11:52 PM
PortlandRL
Sep 14, 2015 12:01 PM
