My TL loses elec. power
Old Oct 5, 2009 | 08:16 PM
yourmom's Avatar
My 2000 TL loses electrical power while driving- dash goes dead and radio cuts out. This only lasts a second and the car can be sitting at idle or moving, so it does not appear to be something loose, like it changes when you hit a bump. You can see a blip in the idle, but the engine does not stall. Checked all the grounds etc. all seems ok.
Anybody ever run across something like this?
The shops want hourly rates to check electrical- my sons car, so i am trying to save him a few bucks.
Old Oct 5, 2009 | 08:17 PM
Ken1997TL's Avatar
Alternator most likely or a belt.
Old Oct 5, 2009 | 10:06 PM
totaledTL's Avatar
Ignition switches reportedly fail on '99s that cause that, not sure about 2000 models.
Old Oct 5, 2009 | 11:43 PM
Gfaze's Avatar
S E L L
My money's on the ignition switch.
Start the car and while it is running, wiggle the key back and forth without changing the position of the key (i.e. don't turn it back off or accidentally crank the starter). Do the symptoms you've been experiencing start to resurface? If so, you have a bad ignition switch. Just because it's not a 99 does not mean it can't fail.
Old Oct 6, 2009 | 07:43 AM
NSXNEXT's Avatar
Call Acura Customer Care and see if your car is covered for the ignition switch recall.
Acura will replace it for free if you're covered.
If not, it's a very simple replacement. Just make sure you disconnect the battery before you work on it.
Old Oct 6, 2009 | 07:55 AM
fsttyms1's Avatar
Being its a 2000 i doubt there is any coverage on the ignition switch. I havent really heard of any 00+ having ignition switch issues. With the car running wiggle the key while its in the ignition to see if you can get it to replicate the issue. Test the alternator, and double check all the grounds, and the positive connection.
Old Oct 6, 2009 | 11:27 AM
D.Greenwood13's Avatar
2000 WDP
mine used to do the same thing, checked the alt and belts and they were fine, never thought about the ignition switch tho
Acura604
20
Aug 5, 2017 12:55 AM
spudweb
May 22, 2016 02:39 PM
knight rider
Mar 4, 2016 08:59 AM
jterp7
3G MDX (2014-2020)
Feb 3, 2016 08:34 PM
95oRANGEcRUSH
Sep 25, 2015 12:50 PM
