multiple cyclinder OBD codes and TCS light
Old Feb 26, 2007 | 04:14 PM
Hey everyone,
i haven't posted in a couple years (since my tranny went out) and my TL has been running smoothly until 2day. I went to start it this afternoon and she was shaking and the check engine light was blinking and the TCS light came on. She's missing so I pulled the codes and got p302 p304 p305 and the one that says multi cylinder misfires. Kind of weirs that so many different cylinders at one time are missing? U changed the plugs about 6 months ago so they should be good? I don't think that all of these coils would go bad at once? It must be something else? Any ideas???? Thanks!!!
Old Feb 26, 2007 | 06:36 PM
fsttyms1's Avatar
possible bad coil pack or 2, or a bad O2 causing it to throw those. I would start with teh coil packs. Work 1 at a time and see if it goes away
Old Feb 26, 2007 | 06:46 PM
Thanks for the reply. But it's throwing codes on 4 different cylinders and it started all at the same time. I think it's unlikely to be a coil problem. If I pulled a miss code on only one cylinder I would swap the coil pack to another cylinder and see if it follows. I'm thinking it must be a vacum leak or an EGR problem or something. She did not throw a vacum or EGR code, but something is making her miss on multiple cyclinders and it's odd that the plugs, wires, or coil would go on 4 cylinders at the same time? Don't you think? She was running great right up to the point of the misfire today. Do you think if it was an 02 sensor or EGR problem it would make it miss on multiple cylinders and not throw a code for any sensors? I do know frome xperience that vacum leaks will make a car miss but I couldn't see any leaks. The plugs and wires also look fine. I'm at a loss.
Old Feb 26, 2007 | 06:48 PM
One more thing, Is it normal for the TCS light to come on when you get a msifire code with a blining CEL?
Old Feb 27, 2007 | 09:23 AM
it was a bad coil
I bought a coil and started swapping it around. Even though I was getting cylinder misfires on 4 different cylinders, it was only one coil that was bad. Only took me 2 tries. All is good now.....
Old Feb 27, 2007 | 09:30 AM
fsttyms1's Avatar
Good deal. Thats why i said to start 1 at a time. Very often our cars show multiple codes when its just 1
Old Feb 27, 2007 | 09:56 AM
firing order and cylinder numbers...
By the way, the cylinder numbers and firing order follow:
By looking into the engine while standing in fron of the car
firewall
123
456
grille/radiator
firing order is 1-4-2-5-3-6
Old Feb 27, 2007 | 09:24 PM
Soseductivesf's Avatar
Damn I think that's the problem I'm having! All sorts of misfiring codes! How much did it cost to fix it?
Old Feb 28, 2007 | 08:53 AM
fsttyms1's Avatar
You can buy A coil pack for around 40 bucks and start going 1 by one on the ones that are reading the misfire
Old Mar 1, 2007 | 08:00 AM
Thanx I'll try that today!
Old Mar 12, 2007 | 09:12 PM
gooddfella's Avatar
EXACT same thing happened to me today right after I got done showing a house. Car shakes a little, TCS light stays on and engine light blinks. I freaked out. But I feel better now I'll try to get the codes checked tomorrow and let you all know what happens.
Old Mar 13, 2007 | 12:13 PM
gooddfella's Avatar
Hey did you try that? did it work?
Old Mar 13, 2007 | 12:30 PM
fsttyms1's Avatar
Get your cods read and see what it says
Old Mar 13, 2007 | 01:49 PM
gooddfella's Avatar
I fuckin love this forum. It cost me less than $60 to get it fixed!! Thanx to this site.
I had 7 codes(1,4 and 6 were misfiring supposedly) I bought one coil and was gonna try all of them until I get to the right one. The first one I tried(6) was IT! I erased the codes and tried agian and now I have "0" codes.
If I didn't come here first I would've gotten rapped at some mechanic shop.
Old Mar 17, 2007 | 10:07 PM
AcuraVibes's Avatar
TeAm InSpIrE
ya i have the same problem but should i changed the coil pack or the ignition coil
Old Mar 18, 2007 | 05:08 AM
Not yet, my mechanic suggested I go back to the dealer since they were the last ones to touch it before that prob. Funny thing is they "claimed" to inspect it & told me it was the egr valves bein' clogged and to adjust my valves! So they want 500 from me! Hell no! My friend's gonna check the coil packs resistance next week to see if thats the prob. If it's not that, I'll have him re gap the plugs and hopefully that'll fix it. I've heard people sayin' egr cleaning is warrantied til 100k. Is it true cuz i have 70k on my 03.
Old Mar 19, 2007 | 08:27 AM
mariusz84's Avatar
I had the same problem, i have 00 tl 93k miles, i changed plugs, colis, and it stopped for a little, but now what it happens, i pulled codes, 9 codes total misfire 1-6 and multiple, and other ones i posted in another forum, i still don't know what it is. when it happens mu check engine comes on, and my TSC and ABS, and none of them work when it happens, i have no idea. im going to the dealer tomorrow to see if they have an idea. also im doing the ignition recall (hopefully). I hate dealers
Old Apr 1, 2007 | 11:10 PM
My friend tested the resistance and we got 19.1 on all the coil packs except 1 which read 17.4! I'm goin' to change that one tommorrow and let you know what happens. It was hard because the cel light would be off most of the time.... i guess i thought the car would "magically" fix itself!
Old Apr 1, 2007 | 11:12 PM
What ignition recall?
Old Apr 2, 2007 | 08:27 AM
mariusz84's Avatar
i think on cars .com i found that some tl's have ignition recall, but i wasn't sure if mine was one of them, they checked and nothing, call a dealer and tell them to check your VIN
Old Apr 2, 2007 | 09:31 AM
fsttyms1's Avatar
Its for the 99s only and its for the Ignition switch.
Like i stated before it could also be a bad O2 causing it as well. (as this has ben the problem for a few here in the past)
Old Apr 2, 2007 | 12:14 PM
gooddfella's Avatar
How can I check the resistance?
Old Apr 2, 2007 | 07:26 PM
I called the dealer and they told me pull the coil out and check for infinate ohms on a multi-meter... after I saw how easy it was to clean the egr valves I did that before buying a coilpack. Can runs a lot smoother so i will see if that fixes the problem!
Old Apr 3, 2007 | 08:59 AM
00 acura tl's Avatar
Inspired
i think im lucky in here my car has 94k kilo and its running good till now
Old Apr 3, 2007 | 09:04 AM
Inspired
well i had engine probleme when i bought the car at 2004. After i changed the engine oil there was a light noise coming out from the engine. i told the dealer and thx god it was uder garantie i got a new engine in no prob till now
Old Apr 5, 2007 | 08:03 PM
Damn.............................................. .same problem....it sucks cuz it only happens wen i start the car in the mornin' then Both VSA & CEL light come on at the same time!..................... I guess I'll buy a coilpack and see if that works but if it dosen't i'm F@%ed! I might clean my CAI first though!
Old Apr 6, 2007 | 08:38 AM
gooddfella's Avatar
I can tell you right now its one of the coil packs. just buy one and try them one by one. Let us know what happens
Old Apr 6, 2007 | 10:43 AM
@ 80+ a pack from Acura dealer, It could be an expensive fix so I want to be sure I test them correctly before buyin' them (no returns on coilpacks)
Old Apr 6, 2007 | 11:08 AM
mariusz84's Avatar
get it online
Old Apr 7, 2007 | 11:36 AM
gooddfella's Avatar
$42.74 on this site http://www.acuraautomotiveparts.org/...p/mws/home.jsp
it would be about $52 after shipping and everything. $80 is too high just call another dealer near you it shouldnt cost you more than $60 after tax from a dealer.
Old Apr 13, 2007 | 12:42 AM
cleaned my cai(pretty dirty) and been drivin' it for 3 days w/ no cel so hopefully that solves the problem...............
Old Sep 27, 2010 | 06:24 PM
amg2y's Avatar
Does it matter if it's original OEM or aftermarket??
Old Sep 27, 2010 | 07:26 PM
01tl4tl's Avatar
this is a 3 year old thread--what exactly is YOUR problem and we will work thru the diagnosis with you
mada51589
Jan 9, 2025 04:40 PM
Yikes
May 3, 2021 04:29 PM
BigJilm
Sep 21, 2015 08:32 PM
cak165
1G TSX Problems & Fixes
Sep 16, 2015 08:17 PM
Bahamanurse1
Sep 10, 2015 10:05 PM
