More Oil Leaks
More Oil Leaks
Been having some oil leaks since I bought my TL 3 years ago. VC gaskets were the culprit one time. The seal under one of the VC hold down bolts was another. The PS hose was another. Yet I have a persistent, rather small leak that plagues me.
While doing some transmission stuff (separate thread), I decide to jump in (or crawl under) to see if I could determine the source of the leak. I did see signs of oil around the "spool assembly" (where the oil filter goes) and will order the gasket.
However I did see signs where the oil pan and transmission meet. I did my best to wipe down everything to get a clear picture. While wiping some other areas I noted more oil running down the pan. Here are the pics.
You can see the fresh line of oil despite having wiped this a few moments earlier.
Here's a close up.
So where do you think this originates?
Since I've done round 1 of a 3x3 transmission drain/fill. I'll be back under it soon to check
Here's a close up.
possibly the oring above the rear main seal. check out this thread for more info...the oring in question is part 21 in the diagrams shown.
https://acurazine.com/forums/second-...6-swap-983133/
