missfire on cyl2
Old Jan 29, 2010 | 12:25 PM
dsalazar1's Avatar
missfire on cyl2
Ok so I have narrowed my missfire down to cyl 2. I used the old mechanics trick unplug them while the engine is running and see which one is down. The coil is good and so is the plug as I have good spark. What could be next? Bad injector? is this an easy DIY or should I take it to the shop? New to the TL so please bear with me. PS its a 99 tl
Old Jan 29, 2010 | 12:36 PM
NSXNEXT's Avatar
How do you know the coil pack is good?
I would just suggest swapping coil pack 2 with one of the others and see if the problem follows the coil pack
Old Jan 29, 2010 | 12:48 PM
dsalazar1's Avatar
I did that. i used a brand new one and moved the one that was in 2 to 3 and 1 and it worked fine. it is really frustrating me.
Old Jan 29, 2010 | 01:06 PM
NSXNEXT's Avatar
maybe a bad injector?
Old Jan 29, 2010 | 01:33 PM
rockstar143's Avatar
I had this happen on my RSX-S too...cyl 3 misfire...so i swapped the OEM coilpacks from 1 and 3 and it never threw out another CEL code.
dsalazar1's Avatar
Checking compression now just to be sure I havent dropped a cylinder. crossing my fingers hopefully its a bad injector and not a bad cylinder.
Old Jan 29, 2010 | 01:57 PM
dsalazar1's Avatar
Just got done checking compression. I get 170-175 on all cylinders except 2 I get 135. Not what I wanted to see. Any suggestions? Cost to fix and is it worth it?
ksu90
Aug 1, 2015 09:12 PM
briggsypn
2G CL Problems & Fixes
May 31, 2015 02:37 PM
Acadien
Oct 12, 2012 08:38 AM
manteuffel
Mar 12, 2006 11:12 PM
aRIff
Nov 9, 2004 12:12 PM
