Misfire issue
Misfire issue
So hey guys i got a 2003 TL TypeS CLs6spd swapped
So i got a misfire between 2500-3krpm but only at those rpms any pointers to what to change beside spark plugs and coils what else should i look for
I would go and clean the EGR and the PCV and see if that helps at all. If you already checked all your plug gaps and rich/lean on the spark plugs, and did the coil isolation test, then EGR and PCV are easy checks/cleanings that could have decent returns on performance. Might want to even give that top end a good cleaning while you're in there. Good Luck!
Check for pinholes in the spark plug wires
I once had the problem at 3200RPM, I found a small hole in one of the plug wires that was arcing. It was very small and I had a small carbon trace on the plug wire that was very hard to see. I never did figure out why it needed 3200 rpm to act up. I changed it out and cleaned up the EGR channels in the intake manifold at the same time( as I was looking at everything I could think of) and the problem went away.
