Misfire issue
Old Mar 24, 2021 | 11:41 PM
PaPi_UA5's Avatar
Misfire issue
So hey guys i got a 2003 TL TypeS CLs6spd swapped
So i got a misfire between 2500-3krpm but only at those rpms any pointers to what to change beside spark plugs and coils what else should i look for
Old Mar 31, 2021 | 06:45 PM
bbsitum's Avatar
In my experience it is COP. But one not all. But OBD will not throw code for single one than for a few and usually one in middle is bad.
Old Apr 1, 2021 | 09:17 AM
Davius's Avatar
I would go and clean the EGR and the PCV and see if that helps at all. If you already checked all your plug gaps and rich/lean on the spark plugs, and did the coil isolation test, then EGR and PCV are easy checks/cleanings that could have decent returns on performance. Might want to even give that top end a good cleaning while you're in there. Good Luck!
Old Apr 1, 2021 | 11:26 PM
Jon M's Avatar
Check for pinholes in the spark plug wires
I once had the problem at 3200RPM, I found a small hole in one of the plug wires that was arcing. It was very small and I had a small carbon trace on the plug wire that was very hard to see. I never did figure out why it needed 3200 rpm to act up. I changed it out and cleaned up the EGR channels in the intake manifold at the same time( as I was looking at everything I could think of) and the problem went away.
Old Apr 2, 2021 | 11:42 AM
whitetiger5's Avatar
are you getting a CEL associated with the misfire? is it consistently the same cylinder, or random? there's a different course of action for each...
taiwoato
1G RDX (2007-2012)
Mar 24, 2021 12:11 PM
Acuratl3535
May 24, 2017 09:08 AM
meazz1
1G TL (1996-1998)
14
Jan 31, 2007 05:44 PM
kevin0171
Nov 17, 2006 08:14 PM
TinyTypeS
Dec 27, 2005 10:19 AM
