misfire in cylinder 1
so check engine light is on i didnt write down the code numbers but it says misfire in cylinder one does this mean the coil or the spark plug? Car is shaking really bad and has a hard time excelerating.
If you are having those other symptoms, I'd be surprised if it was JUST that cylinder.
Get an OBDII bluetooth reader off amazon and use your smart phone to check the codes on the fly.
Easy check to see if it's the coilpack is take your cylinder one coilpack and swap it over to a different cylinder and see if the misfire moves. If it doesn't, then it's the plug (probably). If it does, it's the coilpack.
shake 'n bake
What I did was just unscrew the connector to each of the cylinder's coil, one at a time taking note of the difference in idling,then reattach wiring and go on to the next until the bad one showed up. Replace the faulty coil and the car's engine should run smoother, then reset the code and cross your fingers !
you MUST reset the ecu each time you install a coil--change their positions
so it runs a self test!
that also clears codes
remove the CLOCK fuse from passenger end of dash for a minute and reinsert
thats the secret backup power for the ecu
try cyl 1 first,,thats passenger side against the firewall
numbering rear 123
front 456
when looking from front of car ,,rearwward
numbering rear 123
front 456
The following 3 users liked this post by 01tl4tl:
its the details that make the job done right
dont reset ecu= continue to get bad codes!
SarahSTAR401 (08-23-2012)
I had this issue with our TL and it was the Coil. I just went and unplugged each coil 1 at a time to see if the miss fire got worse. if it did then i knew that Coil worked until i unplugged the 1 and the miss fire didn't change and i knew that was the bad coil. Auto Zone has them for around 50 bucks or less FYI.
The following 2 users liked this post by 04mojogt:
01tl4tl (08-13-2012),
SarahSTAR401 (08-27-2012)
SidhuSaaB
05-30-2020 12:40 AM
joflewbyu2
10-08-2015 11:16 AM
