Memory Seat Setting Problem
Old Jan 21, 2008 | 02:52 AM
bcar473's Avatar
I have a 2003 TL-S and around 3 months after I bought the car from an acquaintance , the power seat memory settings completely went out. Neither button funtions or the key when placed in the ignition will activate the memory settings.
The entire power seat funtions fine, only problem coming from the memory part.
What part has failed? and how much should it cost at the dealer to get it fixed?
(Please forgive me if this has been discussed, I did a couple searches and found nothing about the issue.)
Thank you!
Old Jan 21, 2008 | 06:41 AM
A-SPEK's Avatar
Sorry. I just got my 2003 TL, What is a memory seat? How do you activate it?
Old Jan 21, 2008 | 03:33 PM
bcar473's Avatar
The memory settings for the front driver seat are the two buttons by the door handle, they can be programmed for each of the two keys that are provided with the car.
Mine mysteriously went out and now neither button will respond. What I wondered, was if the mechanism is contained within the door or under the seat or could it be a simple fuse?
Old Feb 22, 2008 | 04:55 PM
Privdog's Avatar
'04 NBP TL AT/Navi
mine also went out recently in my '04 was wondering the same thing. You can program it, or so it seems you hold down the button to stor and it beeps, but it doesn't fucntion when you hit the 1 or 2.
Old Feb 23, 2008 | 04:12 PM
BIGTUFFGUY's Avatar
2003 TL-S A-SPEC
went out as in the buttons dont light up?
or it doesnt auto adjust when you unlock the car?
might just have to hold the lock/unlock at the same time to turn the feature on.
hope its that.
Old Feb 23, 2008 | 09:56 PM
Privdog's Avatar
'04 NBP TL AT/Navi
not working like it doesn't adjust automaticlly of when you push the 1 or 2 button.. i'll try what you suggested when I go back downstairs to the garage. that sounds like it will probably work. I wasn't sure if you could turn the feature off another way then in the keyless memory settings on the dash. Oh wait lol I just noticed also i'm in the 2g forum lol, you guys don't have the dash computer..
Old Feb 23, 2008 | 10:02 PM
BIGTUFFGUY's Avatar
2003 TL-S A-SPEC
:p
Old Feb 26, 2008 | 04:23 PM
bcar473's Avatar
I tried the trick of pressing both buttons, but nothin. The seat memory buttons do nothing when I press them. They give no response on the seat memory function, neither does either remote when pressed.
I don't really want to take the car to the dealership, because of my last experience with the transmission replacement and how much grief they gave me because the car wasn't purchased from their dealership, and it wasn't until I found this website and explained to them that this is a WELL DOCUMENTED problem.... I guess I don't trust them and figure even if there is a repair bulletin, they will pretend it doesn't exist.
Is there a repair bulletin for this problem on this range of second gen TL's?
Old Apr 10, 2008 | 02:40 AM
bcar473's Avatar
Anyone?
rockyboy
Aug 4, 2024 10:35 AM
Feb 25, 2020 09:57 AM
miner
3G RLX (2013+)
36
Jan 11, 2016 04:17 PM
bailey24
Nov 21, 2015 08:43 PM
braveheart
Sep 7, 2015 08:12 AM
