Maybe Overheating???
Old Nov 8, 2009 | 10:49 AM
dannyb22's Avatar
8th Gear
02 tl type-s.
Started this week, car temp sensor gauge goes up near hot while in park. When I drive the car its on normal reading even while driving long distances. As soon as put the car in park and wait about 5 minutes temp gauge goes up. When I turn the car off both fans kick in to cool off engine for a couple of minutes. I check the cool level and thats good, there are no coolant leaks. Replaced ECT sensor. Any Ideas???
Old Nov 8, 2009 | 12:05 PM
friesm2000's Avatar
B A N N E D
Originally Posted by dannyb22
02 tl type-s.
try a new thermostat, proably stuck partially closed, try increasing the revs at idle to get the coolant flowing and see if it starts to overheat then
also might be a plugged radiater; internaly (coolant passages) and/or externally (the fins) IDK
also is the coolant a 50/50 mix of coolant and water; coolant protects from corrosion, drops the freezing point, raises the boiling point, etc. ,etc. while the water is what actually does the work of keeping the engine cool by carrying away the heat from the block to the radiater
Old Nov 8, 2009 | 11:10 PM
dannyb22's Avatar
8th Gear
ok thanks i will look into this during the week.
Frathora
Sep 28, 2015 11:29 PM
NSolace
Sep 3, 2015 08:14 PM
NSolace
Sep 3, 2015 08:02 PM
Jezek
Jun 20, 2006 11:30 PM
gincali
May 17, 2006 09:01 PM
