many problems with my TL 00
Old Jan 23, 2011 | 11:08 PM
dragonman's Avatar
Hi guys well my acura tls got a bit of problems and i was wondering if you guys can help me fix it, Well first of all the back up light on my clock doesn't work.Second the cigarette
lighter doesn't work. Third the middle fan doesn't seems to be blowing very hard , even when i max it . fourth the lights on the shifter doesn't show up to. Any one know whats wrong with my car? Thank you
Old Jan 24, 2011 | 01:24 AM
01tl4tl's Avatar
ck the fuse boxes- there are several things tied to the clock and lighter power
Old Jan 24, 2011 | 01:52 AM
ParaSurfer1979's Avatar
Noone can know unless we looked at it. Take to a mech.
Old Jan 24, 2011 | 09:41 AM
fsttyms1's Avatar
1). You need to replace the bulb behind the clock, you need to remove the whole trim piece to access it
2). Check the fuse for the cig lighter. (and make sure a dime isnt in it, it is more common than you know causing it to blow a fuse) The fuse should be in the passengers side dash fuse panel
3). You may have a mix motor that is stuck or sticking? DOes it blow from the other vents ok when set to defrost or floor?
4). The light by the shifter is burned out. You need to replace it as well. Pop off the trim panels around the shifter, get a needle nose pliers and pull the bulb out and replace it.
Old Jan 24, 2011 | 07:57 PM
dragonman's Avatar
thank you soo muchh . im going to try it. haha would you have any pics of it. haha go packers
Old Jan 24, 2011 | 09:56 PM
fsttyms1's Avatar
pics of what?
Old Jan 24, 2011 | 09:57 PM
dragonman's Avatar
to remove the the dash board for the clock and the shifter
SidhuSaaB
May 30, 2020 12:40 AM
Fool
Mar 10, 2016 08:42 PM
12vancover
Oct 16, 2015 12:04 PM
Matthew Purpura
Sep 25, 2015 06:10 PM
MikeJM310
Sep 24, 2015 07:24 PM
