Malfunction Indicator Lamp????? Help!!
Old Jun 13, 2010 | 09:48 AM
NYanks78's Avatar
Can anyone help???? I was at a concert last week and I had my doors and music on while listening to music and my battery died, so I jumped the car and since then my Malfunction Indicator Lamp has been on and Im trying to get it off.
I read in the owners manuel that the light comes one when it singals a problem but it doesnt say how to reset it, the book also says that it wont go off right away and that it will take up to 3 trips for the light to off off. I have driven way more than 3 trips and the light is still on, It wasnever one before that and the car runs great. So I really didnt want to bring it in on service for that reason.
Has anyone ever had this issue? The yellow light on the dash that looks like a engie and says "check" on it. I wanted to know if their is a way to reset it instead of bring it in for service, any help is appricate it. Thank You
Old Jun 13, 2010 | 10:08 AM
dudeinaTL's Avatar
Remove fuse #13 from passenger-side fuse box for a couple minutes, then replace it.
However, you should go to AutoZone and read what code is signaling the lamp before resetting.
Old Jun 13, 2010 | 10:36 AM
NYanks78's Avatar
Ok thank you, Ill try it now
Old Jun 13, 2010 | 11:17 AM
01tl4tl's Avatar
CEL-ck engine light- is a general warning light to get you to look under the hood
can mean anything
Battery could be weak if over 3 years old and dies while in use
When you jumped the car and drove home.. with alternator working overtime to recharge dead battery- that could trigger a code, false or real..often false when battery low as sensors not getting correct voltage fool everything
its free at parts stores to come out with a code reader- it plugs in behind a panel between the seat heat switches-- behind shifter
note- when battery is dead like this- its much better for the car if you can recharge battery with a machine to get it mostly full- then let the alternator do the remainder
Alternator not made to recharge from dead- just replaces whats being used at any moment~
after you give us the codes- or google them - you can clear the light by pulling the CLOCK fuse as said above- its the secret backup power for the ecu=engine control unit.
about a minute is good then reinsert , start car and drive normally
the car will do a series of self test and system reboot
a few days later get the codes ckd again to assure they are gone-means they were false from low voltage
the one about `a few days to clear CEL` is usually if you dont tighten the gas cap the required 3 clicks or more
thats a torque spring in the cap so you know its at right amount of tight
Left loose or off.. even for a few blocks.. and car stumbles so you put cap back on
It can take days for the system to clear and reset
Old Jun 13, 2010 | 05:59 PM
NYanks78's Avatar
Thanks A lot, I removed the fuse and put it back in and the light is gone, Thank A lot!!!!
Old Jun 13, 2010 | 07:03 PM
01tl4tl's Avatar
good but still get the charging system ckd
Old Jun 15, 2010 | 09:22 PM
NYanks78's Avatar
Ok I will, Thank You
SilverJ
4G TL Problems & Fixes
15
Oct 13, 2015 05:14 PM
detailersdomain
Wash & Wax
Oct 9, 2015 10:13 PM
jubikej
1G RDX Problems & Fixes
Sep 30, 2015 01:13 PM
h22lude
Sep 27, 2015 06:22 PM
Eggs999bacon
Sep 24, 2015 10:08 AM
