Maintenance Required Light Started Flashing
Old Jan 29, 2008 | 09:04 PM
Razzi's Avatar
T-Swzy
Question Maintenance Required Light Started Flashing
got my 1999 tl at 80000 miles. everything was fine and dandy mechanically. then at 84500 miles the maint. req. light started flashing slowly for about 6 or 7 times when i started my car up. it does go away tho. thought it might be oil, nope, still clear and up to level. brought it into a shop, had 2 mechanics looked at it.
one of them also drives a 2nd gen tl. finally they said it's telling me to reset something, i didnt quite catch it. he said ur suppose to reset something or some shit whenever you change the oil. i havent seen that with any car ever, so i thought it was kinda strange. theyre family so i didnt think they'd steer me wrong. so what the guy did was got in the car, hold down the odometer reset button, shifted it into D4 for about 10 seconds, then back into park. he said it should be fine.
i started the car up, the light flashes again and goes away. now i know technically if it's not on there's nothing wrong. but it wasnt on at all before, so i wanna know if i should be worried.
Old Jan 29, 2008 | 10:43 PM
rob-2's Avatar
On my 2nd gen it's counting down to going solid which is when you need to get service. I believe it's only miles driven and nothing else.
Old Jan 29, 2008 | 11:21 PM
Bob_F's Avatar
Yes, it's just a counter and it will go from flashing to solid when you reach 7,500 miles since the last time it was reset. It's just a reminder for an oil and filter change.
There's no need to shift gears to reset the counter.
The actual steps are in the owners manual and they're posted in a number of threads.
Old Jan 30, 2008 | 02:03 AM
01tl4tl's Avatar
Heres your owner book link
https://techinfo.honda.com/rjanisis/...01_OMANUAL.asp
Old Jan 30, 2008 | 07:40 AM
Razzi's Avatar
T-Swzy
as always for AZine
Old Jan 30, 2008 | 10:16 AM
fsttyms1's Avatar
you dont shift it to any gear. just push and hold the trip and reset buttons in, then while holding them in turn the key to the run position. Continue holding them till the Maint req lite goes off (about 10 seconds) You are supposed to reset it at every oil change. Its the reminder to change your oil when it goes on solid. It will flash on start up when its getting close
Next time
Old Jan 30, 2008 | 07:12 PM
Razzi's Avatar
T-Swzy
yeah i'll be sure too, i used the firefox's function for 3 pages and all i found was this https://acurazine.com/forums/showthread.php?t=172137. so i figured i'd take the lazy bastard's way out
by run you mean the motor start right?
Old Jan 30, 2008 | 07:48 PM
fsttyms1's Avatar
There is a Search function in 2 places on this page that will search only the forum. It works, and would have given you many more results, page fulls.
And NO. To the run position, Not Start the car. The run position is where the key goes to when you let off from cranking it over/starting
Old Jan 30, 2008 | 09:48 PM
Razzi's Avatar
T-Swzy
so the one where u get all your electrical stuff going. thanks kris, saved yet another TL
redsox68
Sep 16, 2015 06:18 PM
PortlandRL
Sep 14, 2015 12:01 PM
HeloDown
Sep 8, 2015 06:51 PM
darknite123
Integra
Aug 30, 2015 03:00 PM
ptbarnett
3G RLX (2013+)
Aug 30, 2015 12:39 PM
