Maintenance on old trans with unknown history
#41
#42
Likewise, it's Acura recommend in emergency use. Never say never.
#43
I'm in 01alcs's camp. After 2 failed transmissions (at around 100k miles each) I switched to an '07 AV6 trans and have run MaxLife in it from the beginning. The tranny had ~56k on it when I got it. I've put over 100k on it since then, changing the fluid and external filter somewhat regularly and have had no issues. Prior to switching to MaxLife, I researched as best I could via BobIsTheOilGuy's site and the Odyssey forums. Many people are using MaxLife without issue. Is DW-1 the "safe" choice? Sure. Does that mean it's better? From my experience and experience of many others, I don't believe so.
#44
#45
I would like to add my recent experience on trans oil to this thread. I have a 99 since almost new, trans was rebuilt once 6 years ago, oil always changed regularly and very well maintained car ( by owner mostly) We decided to change the trans oil after 30k, drained 3 qts out the filler tube with a sump. Oil ( from trans rebuild ) looked very good. We put in Redline synthetic, exact same amount. The trans was working fine no issues, except it shifted slightly late at low speeds, and not as smooth as when new. The change in behavior was very noticeable after the fluid change, and immediate. I had 2 other drivers of the car check it out and they were surprised and could tell the shifts were smoother, very consistent, like when the car was new. Can't wait to complete the 3 X 3 process, this can't be other than a better quality fluid imo.
I hope this helps someone along the way. My guess is the transmission shop uses whatever is in the 45 gallon drums they buy, but it's not the quality of a higher grade oil.
I have a Tacoma in which I replaced the trans oil with Valvoline Max Life synthetic and noticed and slight increase in smoothness and shifting, not as dramatic as this. It was running on original Toyota fluid which had been changed once at 50K and I added the Max Life at 80K.
#47
You're taking advice from a youtube mechanic that says it's ok to use compression fittings on brake lines and no need to use jack-stands when doing oil changes? Good luck...
#49
Yep, I'd stick with Scotty VROOM, VROOM, VROOM Kilmer's recommendations. ( " it's ok to use compression fittings on brake lines and no need to use jack-stands" ) He's a mechanical *** GENIOUS***!
#50
Z1, nor DW1, were at responsible for premature failures, impacting the 2G TL models. The bottom line, these specific transmissions failed, due to DESIGN QUALITY ISSUES, not oil quality problems! It likely, would't matter, it you changed the transmission fluid, as often, as you changed your engine oil, they would still FAIL!
#52
---"I worked 20 years at the biggest trucking co. in the us as a diesel mechanic , and we had to change transmissions and differentials on a frightening high rate until we started using synthetic gear lube, after that we nearly had to close the rebuild shop because we didnt have the business. Also we started using synthetic blend motor oil and doubled the oil change interval to 25000 miles, that's not a typo, we also went from 350,000 trade in intervals to over 1,000,000 trade in interval ask Yellow freight i have been retired since 95 so some things could have changed but I'm telling it like it was"---
#53
Skirmich
1/2G MDX (2001-2013)
12-06-2019 10:45 AM
Sperry
05-01-2012 12:13 PM
