? Location of A/C Pressure Switch & A/C Diode
Old May 3, 2007 | 09:21 PM
shevy77's Avatar
6th Gear
2002 TL Type-S
Could someone provide the location of the A/C Pressure switch and/or A/C Diode? I am running through a troubleshooting procedure and need to be able to locate these.
Old May 3, 2007 | 10:38 PM
fsttyms1's Avatar
I believe its Part 13
Old May 4, 2007 | 02:26 PM
shevy77's Avatar
6th Gear
Thanks fsttyms1.
Old May 29, 2007 | 07:08 AM
mshiwpal's Avatar
5th Gear
Nice diagram
My AC is not blowing out cold air...i'm sure it needs to be charged but i'm not sure where the charging port is...does the diagram show the location, if so please let me know what #, if not can you tell me how/where to charge the AC?
Old May 29, 2007 | 08:10 AM
VTEC11's Avatar
Originally Posted by mshiwpal
Nice diagram
Charge from the Low Side port, which is #15 from the diagram. I would start with just a half can of R134a and see if it makes a difference. You don't want to overcharge it. Is your compressor turning?
Old May 30, 2007 | 06:13 PM
mshiwpal's Avatar
5th Gear
compressor is definately turning over...just not getting COLD COLD air! I will try to find the port and use only half can of R134a and see if that does the trick :P
Old May 30, 2007 | 07:49 PM
fsttyms1's Avatar
you should have it checked to see what teh pressure is. It cant be that high.
Old Jun 1, 2007 | 12:32 PM
mshiwpal's Avatar
5th Gear
Thanks for all the help fellas! I charged the system, now i'm getting some nice cold air which helps me survive the summer heat
Old Jun 1, 2007 | 06:38 PM
sbuswell's Avatar
I need 2 more gears
related question. I changed my serpentine belt in the winter and now my AC is not blowing cold air. The compressor is coming on, but the air isn't very cold. It does feel a little cool though. When the belt was changed could the AC tensioner have loosened up enough for it to leak?
Old Jun 28, 2010 | 10:01 AM
Mack96AcTL's Avatar
I do not see the diagram here.. can someone help me out. I also need to locate the a/c low pressure port... Thanks
mike from annapolis
May 7, 2017 08:21 PM
Sep 17, 2015 10:09 AM
MyGuti
Sep 12, 2015 06:52 PM
DS2000TL
Sep 9, 2015 09:26 PM
dlknight
Sep 3, 2015 07:54 PM
