knocking noise left front A-arm
Old Apr 6, 2008 | 05:10 PM
sleeperblue's Avatar
I hear a loud knocking noise every time I hit a bump, with the car in the air (jackstands of course) I moved each suspension piece and it is the upper A-arm that appears to be loose enough to make the noise. So, the question... what am I looking at to fix this, money and time... thanks for any responses...
Old Apr 6, 2008 | 07:41 PM
fsttyms1's Avatar
Its probably the upper ball joint. You can get just the ball joint and have it pressed in or you can buy the whole arm. You can get the whole arm and ball joint here for 66 bucks.
http://www.macautoparts.net/Catalog....ategoryid=5900
Old Apr 6, 2008 | 11:06 PM
illmat1k's Avatar
Thass Wassup!
Sounds like you're bushings are probably worn out. I had the same problem with my 6th Gen Accord.
Old Apr 21, 2008 | 08:52 AM
lokee99's Avatar
I'm stock and hating it.
I am hearing that same sound now but haven't looked under there.
Old Apr 21, 2008 | 11:06 AM
fsttyms1's Avatar
Check your ball joints.
Old Apr 21, 2008 | 05:25 PM
rob-2's Avatar
Where do you find the right bushings and are they easy to install yourself?
Old Apr 21, 2008 | 09:14 PM
fsttyms1's Avatar
You dont. Odds are any clunking is from the ball joints or the sway bar end links. Given the age that our cars are getting its a good idea to replace the upper a-arm so that it comes with a new ball joint and new bushings in the control arm. Also replace the lower ball joint and lower control arm so that you get new bushings in that as well
Old Apr 21, 2008 | 11:33 PM
rob-2's Avatar
Any idea on price?
Feb 25, 2020 09:57 AM
PortlandRL
Sep 14, 2015 12:01 PM
08 NBP TL
Sep 8, 2015 08:49 PM
ptbarnett
3G RLX (2013+)
Aug 30, 2015 12:39 PM
