Key Won't Turn
Old 08-08-2007, 07:33 PM
5th Gear
bubinga2's Avatar
Unhappy Key Won't Turn
:surrender Ok, so I'm changing the ignition switch because once a month or so my 2000 TL won't start. Now the key won't turn. What did I do wrong? I looks like the immobilizer is keeping me from stealing my own car. Can you help me? :surrender
Old 08-08-2007, 11:32 PM
Mike's Silver Bullet
6spMike's Avatar
It's not just the steering wheel lock?
Old 08-08-2007, 11:39 PM
EL19's Avatar
try turning the steerng wheel and turning the key at the same time
Old 08-08-2007, 11:44 PM
I'm your Huckleberry
RockOut's Avatar
Hopefully its not what happened to my wife's Pilot. She accidently put our Ford Explorer key in the ignition. It stuck a little but she pulled it back out. When she put the Honda key in, nothing happened. When I got there I realized the immobilizer had activated, but apparently several of the pins in the ignition lock were damaged and they had to put it on a roll-back and take it to the dealer.
It cost us roughly $250 to have fixed.
Old 08-09-2007, 07:57 AM
lostchild83's Avatar
Check your key first, see if there's anything wrong with it. I had trouble turning my key when i noticed it was slightly bent. like a tiny little bit.
Or try using your second set of key to see if it turns properly.
Hope this helps!
Old 08-09-2007, 08:41 AM
5th Gear
bubinga2's Avatar
you're right, the steering wheel was in a position that put preasure on the key. when I moved the steering wheel then the key turned fine. time for reassembly. thanks!!!!
rockyboy
08-04-2024 10:35 AM
Powder Monkey
2G CL Problems & Fixes
09-09-2018 12:55 AM
PortlandRL
09-14-2015 12:01 PM
whitesoxsfan12
09-13-2015 02:09 PM
prox
5G TLX Problems & Fixes
09-01-2015 02:03 AM
Quick Reply: Key Won't Turn
