Just what i need!! front end clunking while driving
Old Dec 3, 2008 | 05:06 PM
sfont012's Avatar
here comes the snow!
noticed this morning, getting a repeated clunking sound and feeling as i drive. the faster i go the faster and worse it gets. It seems like its coming from the front wheels, and i can feel it in the steering wheel.
started to get worse as i was driving home. I actually had to put my hazards on and drive home like at 10 mph. i thought my wheels were going to fall off or something. I looked under the car for anything obvious but did not see anything, but then again i have no idea what to look for. I was thinking suspension parts or steering but i dont know.
any ideas anybody??
Old Dec 3, 2008 | 06:09 PM
FirePR2002's Avatar
bringin lead
could it be a tire problem - or a bent rim? how do the tires look?
Old Dec 3, 2008 | 06:32 PM
sfont012's Avatar
they look good, just put the stock wheels and tires back on about 2 weeks ago. could be a bent rim. would have to have hit something though and dont remember hitting anything.
ill check as soon as i get a chance.
Old Dec 3, 2008 | 06:37 PM
FirePR2002's Avatar
bringin lead
did this start when you put the stockies back on? if so, there's your problem.
Old Dec 3, 2008 | 06:50 PM
fsttyms1's Avatar
Double check that the lugs are tight. Also inspect the axles for play
Old Dec 3, 2008 | 07:29 PM
Agentphan007's Avatar
loose lug nuts
Old Dec 3, 2008 | 10:30 PM
totaledTL's Avatar
Had similar issue one time on a different car. Had somebody rework the front brakes & they forgot to tighten the caliper mtg. bolts on one side. Started vibrating, one bolt fell out. Felt like the wheels were loose.
Old Dec 4, 2008 | 01:52 AM
Gfaze's Avatar
S E L L
Since you said you just swapped wheels two weeks ago, they may have come loose since then. You're supposed to re-torque them after about a 100 miles.
Old Dec 4, 2008 | 06:06 AM
sfont012's Avatar
im going to check to the lug nuts as soon as i get a chance. today after work. using my girls car right now.
Old Dec 4, 2008 | 12:19 PM
TLer trash's Avatar
I've seen ice/snow buildup inside the wheels do this as well.
Old Dec 4, 2008 | 12:52 PM
Neejay's Avatar
Definitely update us. I'm having the same problem, but it's more of a squeaking noise too.
Old Dec 4, 2008 | 01:00 PM
sfont012's Avatar
I get home at 6.
daam i hope its lugnuts. please!!!!!!!!!!!!!!!!!!!!
Old Dec 4, 2008 | 01:23 PM
Neejay's Avatar
I get home at 6.
+1 - for you and I, both. lol
Old Dec 4, 2008 | 07:11 PM
sfont012's Avatar
checked the lug nuts, they are definately loose!!!!!!!!!!!!!!! YES!!!!!!!!!!!!!!!!!!!!!
NeeJay good luck dawg!!! hope its an easy fix for you too!!!!!
Feb 25, 2020 09:57 AM
TLDude876
Dec 28, 2016 03:18 PM
08 NBP TL
Sep 8, 2015 08:49 PM
