Intake Manifold Issue
Old Sep 20, 2012 | 04:11 PM
jdubbs11ghost's Avatar
I got a little adventurous this morning and when i got into my intake manifold this is what I saw. There is oil, small rust particles, and corroded metal. What can I do? Is there a deeper problem that I need to get checked out? seafoam?
Also, I am not sure as to why I cant see my picture. could someone let me know if I can make a change to my settings to allow myself to see all pictures posted? half of them don't show up on this site. Thanks.
Old Sep 20, 2012 | 04:43 PM
01tl4tl's Avatar
use a photo hosting site (free) and click the box for sizing- `for web page display`
then copy that link and paste on the page you are working on here
it will display for all then!
oil in the top of the intake is normal, part of the blowby
replace your PCV (10$)
what other stuff is there, does it look like leaks from coolant or compression?
corroded inside ore outside of manifold working area?
cleaning the port/passage thru length of manifold now?
note= the upper cover gasket is easily flipped upside down, and will fit but block egr port!
making you repeat the job to flip it back right side up
ck against top piece, not the engine block side,
Old Sep 20, 2012 | 04:48 PM
01tl4tl's Avatar
just viewed pic, looks like plugged egr system
carbon buildup and blowby
use carb cleaner to soften crud then a wire coat hanger to poke poke poke and pull crud out of each port to cylinder, and the length of internal passage
expect 3 to 4 cans carb cleaner to do a good job
the main passage from the 2 holes under egr valve goes thru to the other end where its wide and has all that crud on the walls etc
Old Sep 21, 2012 | 09:13 AM
victus1's Avatar
Yep, looks just like mine did before I cleaned it. Get yourself a few cans of carb cleaner and lots of rags to clean up this mess. You really need to take your time and clean out the egr port holes until all the crud is gone. I would also recommend you remove the EGR valve itself, clean it and the port on the block with carb cleaner, then lubricate the arm of the egr valve. You will need a new gasket after you remove it...it's cheap.
Old Sep 21, 2012 | 11:50 AM
01tl4tl's Avatar
you must remove the egr valve and go thru the 2 holes below it- into the intake manifold with the wire coat hanger--do it from the other end of manifold too--where the large opening with crud is
that passage leads all the way to each cylinder, if not cleaned it wont flow right
If you dont get the length of the passage it, and do just the ports, its still not fixed!
Old Sep 21, 2012 | 08:29 PM
fsttyms1's Avatar
Thats normal looking for an uncleaned egr port. Like the others said, take it apart and clean it.
Old Sep 22, 2012 | 07:16 PM
Thanks to everyone who has replied. I have yet to get working on this because I just recently had all 4 wisdom teeth removed, but when I do, Ill let you guys know how it goes. thank you so much for the help.
Old Sep 22, 2012 | 10:39 PM
01tl4tl's Avatar
you know you set yourself up for this one right?
So they removed all your wisdom, NOW you want to work on the car!!!,,,greaaaaaaat
another noob thread,,,`car wont run after egr work`,,
I dropped a vicoden in the intake, will the car act sleepy or drive crazy?
Old Nov 22, 2012 | 09:40 AM
mrbustrbrown's Avatar
dam,thats bad....just did mine and it was half that dirty,155k 2000 tl...looks like it had never been done,but yours is way dirtier than mine,but i to had the oil chillin in the intake,dont know how it got there but now ill look into a pcv...
cycdaniel
Dec 17, 2019 10:58 AM
james357
Feb 13, 2016 02:37 PM
kmarqueling
Oct 3, 2015 01:14 AM
JarrettLauderdale
2G CL Dynograph Gallery
Sep 21, 2015 07:51 PM
EvilVirus
Aug 31, 2015 05:24 PM
