Info seeker!
Old Mar 13, 2009 | 12:13 PM
spiro's Avatar
Info seeker!
Things im not sure if you will need but i bought.
Relay box assembly (under hood) 38250-S3M-A21
Shift Boot 83414-S3M-A01ZA
Shift Knob 54102-SL0-023ZB
If you have a header you will either have to have the XS header or COmptech header for the manual. Other wise it wont fit
You will be able to reuse the stock manifolds
[B][COLOR="Red"]If you already ahve a Type-s you MAY Not need these????
Right side cabin to engine comp harness 32100-S3M-A12
Left side cabin to engine comp harness 32120-S3M-A20
I Would attempt with out (that i bought and used with out trying without first) It will make not having to do all the rewiring of
that i did.
Upper instrument harness 32117-S3M-A31
Lower dash harness 32150-S3M-A32
fsttyms1
Should someone attempt this without these parts and then find out they are needed. How much work is it to go back and install these?
Old Mar 13, 2009 | 12:42 PM
fsttyms1's Avatar
Kinda a vague post but i assume you attempting the 6 speed swap? Why dont you check into the modules. It will make life much easier on you
Old Mar 13, 2009 | 01:19 PM
spiro's Avatar
I am thinking about it. I have a TL-P, using the module will leave me wanting the higher powered CL-S motor at some point. So I am thinking, why not do it now and get it over with. Also I should add I am in touch with a wrecker who is willing to sell me the cls motor and trans attached with about 60000 mls for like 2 grand. the motor is still in the car so If I am sure ,what is needed I can make a one time deal.
TypeS860
Jan 10, 2026 11:11 AM
MrHeeltoe
20
Feb 23, 2023 01:54 PM
rcs86
Aug 2, 2016 06:52 PM
MrHeeltoe
Sep 29, 2015 10:43 PM
MrHeeltoe
Sep 28, 2015 05:43 PM
