Info seeker!
Info seeker!
Things im not sure if you will need but i bought.
Relay box assembly (under hood) 38250-S3M-A21
Shift Boot 83414-S3M-A01ZA
Shift Knob 54102-SL0-023ZB
If you have a header you will either have to have the XS header or COmptech header for the manual. Other wise it wont fit
You will be able to reuse the stock manifolds
[B][COLOR="Red"]If you already ahve a Type-s you MAY Not need these????
Right side cabin to engine comp harness 32100-S3M-A12
Left side cabin to engine comp harness 32120-S3M-A20
I Would attempt with out (that i bought and used with out trying without first) It will make not having to do all the rewiring of
that i did.
Upper instrument harness 32117-S3M-A31
Lower dash harness 32150-S3M-A32
fsttyms1
Should someone attempt this without these parts and then find out they are needed. How much work is it to go back and install these?
that i did.
fsttyms1
I am thinking about it. I have a TL-P, using the module will leave me wanting the higher powered CL-S motor at some point. So I am thinking, why not do it now and get it over with. Also I should add I am in touch with a wrecker who is willing to sell me the cls motor and trans attached with about 60000 mls for like 2 grand. the motor is still in the car so If I am sure ,what is needed I can make a one time deal.
MrHeeltoe
20
02-23-2023 01:54 PM
rcs86
08-02-2016 06:52 PM
MrHeeltoe
09-29-2015 10:43 PM
MrHeeltoe
09-28-2015 05:43 PM
