Immobilizer issue
Old May 7, 2012 | 02:27 PM
yeedatoy's Avatar
kill you till you die
Immobilizer issue
For a while my TL has has issues starting, I've noticed that the Immobilizer light decides not to come on sometimes. A whack of the steering wheel will trigger the light and the car will crank no problem. I assume the unit is under the steering wheel cover? Does anyone know how to replace the unit or what it entails? Can I simply swap i out or do i need to have it reprogrammed etc. It's become more frequent lately and I may be stuck soon! Thanks
Old May 7, 2012 | 09:01 PM
yeedatoy's Avatar
Shit.
Old May 8, 2012 | 04:21 PM
fsttyms1's Avatar
Yes, you can replace just the immobilizer unit. Its very easy. When you say a whack of the column it cranks just fine, before that does it crank or no?
Old May 9, 2012 | 10:13 PM
yeedatoy's Avatar
thanks. It tries to start but just wont turn over completely. the green immobilizer light is not visible whenever this occurs. If i leave the key in the on position and hit the wheel the light comes on and the car starts normally. Do I just replace the small black box and ring around the key hole? I assume it's just failing for some reason....or can the actual chip in the key wear out?
Old May 15, 2012 | 10:15 PM
yeedatoy's Avatar
Old May 23, 2012 | 11:50 PM
zeroicea's Avatar
This may or may not help you.....
http://www.acura-tsx.com/forums/showthread.php?t=794155
Originally Posted by yeedatoy
Old Jun 4, 2012 | 08:52 PM
yeedatoy's Avatar
well, I replaced the immobilizer unit and the problem is still there. It seems to happen more on a hot day. Smack the wheel and the car starts fine...any other ideas? I noticed the SRS light does not come on sometimes as well when the immobilizer light doesn't illuminate.
Old Jul 20, 2012 | 02:52 PM
yeedatoy's Avatar
It turned out to be a bad connection on the main relay/ fuel pump relay under the dash. I swapped relays and no longer have an issue in case this problem arises for someone else.
Kres43
1G RDX (2007-2012)
Oct 3, 2015 07:16 PM
Frathora
Sep 28, 2015 11:29 PM
tristann616
1/2G MDX (2001-2013)
Sep 22, 2015 11:40 PM
carz0159
Sep 20, 2015 06:11 PM
whitesoxsfan12
Sep 13, 2015 02:09 PM
