Idle problem
Old Aug 29, 2010 | 05:08 PM
ace1414's Avatar
Idle problem
Ok I change the map sensor and iacv car runs find but cel and tsc light are on? I spray crab cleaner next to he TB,the vacuum line in the throttle body next to the TB and Manifold cut out
Old Aug 29, 2010 | 05:18 PM
ace1414's Avatar
I'm don't sure whats it call but it's next to the TB
Old Aug 29, 2010 | 05:51 PM
hANDYcaptd's Avatar
It's the Halladay season!
Get the codes read before you do anything else. Don't waste your time without knowing exactly what's wrong.
Old Aug 29, 2010 | 08:30 PM
01tl4tl's Avatar
guessing you took the entire TB off the manifold to flip over and clean IACV?
did you replace the gasket between manifold and TB??
must be spotless clean of old gasket then install new one and torque very carefully!!
not much pressure and its too tight!
ckd all bolts with torque wrench ?
recheck all your work
If manifold top was off- its gasket can be flipped upside down- still fit,, but block an important port and run bad
have to remove top cover and flip gasket- match it so it fits the top cover side
Old Aug 30, 2010 | 05:22 AM
ace1414's Avatar
Code p0505 idle air controll valve,I bought a new map sensor and iacv
4drviper
Apr 23, 2025 07:13 PM
SidhuSaaB
May 30, 2020 12:40 AM
mdlex389
4G TL Problems & Fixes
Sep 28, 2015 06:29 PM
Matthew Purpura
Sep 25, 2015 06:10 PM
TL14
Sep 24, 2015 04:37 PM
