i got a vtec malfunction 99 tl-p
Old Feb 23, 2014 | 06:03 PM
premiumspeed's Avatar
chek engune just came on. Went to getvit checked out and found out its a vtec malfunction. Now wtf!! . Does anybody know what i should to fix it or chek what itcoild be?!
Old Feb 23, 2014 | 06:22 PM
vtec operates off of oil.
Check to see if your oil level is not low.
2nd, if you could give us the EXACT code, it would be VERY beneficial to us
Old Feb 23, 2014 | 07:54 PM
ErickUa5's Avatar
Mr.Helpful Diagram
+1 on low oil, also what weight oil are you using?
Engine off and warmed up to check it.
Old Feb 24, 2014 | 07:27 AM
3.2TLc's Avatar
Yeah, perhaps the oil filter is getting old and grungy. If it's been awhile, try a fresh oil change.
Depending on the actual code, ya may want to consider pulling the oil filter assembly which also contains the VTEC solenoid. Could be that the VTEC is sticking or it's screen is gunked up ?
Old Feb 24, 2014 | 07:43 AM
P1259 is the code.
The code was ia p1259, im using 10-30 castrol. Idk wtf. I think i should seafoam and then change oil. I hope i dont have to change the solenoid
Old Feb 24, 2014 | 07:58 AM
3.2TLc's Avatar
Check the wiring connections to the VTEC solenoid. Also, it cold possibly be a faulty oil pressure switch.
Old Feb 27, 2014 | 06:56 AM
I was using 10-30 should i use a thicker oil? Its gonna get hot this summer. What would you recomend
Old Feb 27, 2014 | 07:51 PM
ErickUa5's Avatar
Mr.Helpful Diagram
What I meant to ask was whats the oil level ? check the dipstick with engine off then clean it, put back in then check the level (it should be between the dots) but make sure its on a level surface before checking.
If its low fill back up.
I have always used 5w30, don't use any thicker oil than what you using.
If it was low check for leaks that may have caused it to go low.
IBankMouse
Jun 13, 2020 12:53 PM
hedzup
1G RL (1996-2004)
Jun 29, 2016 08:07 AM
HeloDown
Sep 8, 2015 06:51 PM
Desert Ridge
Sep 5, 2015 09:47 AM
LAMike240
Sep 3, 2015 04:35 PM
