How should i fix my ugly pillars?
Old Jan 16, 2011 | 01:00 AM
KobeAllDay's Avatar
Well everytime i head into my car, i see those ugly pillars where some parts of it has that shiny gloss to it and some parts doesnt, is there a way to recoat it or replace it? i saw 03tlsnbp's plastidip ones and they looked good. should i do this?
Old Jan 16, 2011 | 02:14 AM
Karanx7's Avatar
Unregistered Member
http://www.soaap.com/auto/images/pro...AP-MM-2181.jpg
You mean the B pillars in that picture? I also would like a solution, as mine are in poor condition (sun damage?).
Old Jan 16, 2011 | 02:53 AM
02TL4ATL's Avatar
theres a diy for it in the diy section.
Old Jan 16, 2011 | 02:57 AM
02TL4ATL's Avatar
i need to redo my b pillar as well. i tried the vinly wrap but it didnt turn out as good as i hoped.
Old Jan 16, 2011 | 06:09 AM
Carbuff's Avatar
Original Owner / Oct 1998
It's a different look,
But I covered my B pillars with polished Stainless Steel from an Ebay vendor. Came out OK.
Old Jan 16, 2011 | 12:01 PM
KobeAllDay's Avatar
i dont want to completely removie it...
Old Jan 16, 2011 | 12:16 PM
thelastaspec's Avatar
uʍop ǝpısdn ǝdʎʇ uɐɔ ı
I might ask the bodyshop im getting my hood repainted at how much it would be to paint the pillars NBP. Body colored pillars might be nice...
Old Jan 16, 2011 | 02:17 PM
Carbuff's Avatar
I considered painting the plastic...but it is actually deteriorating, becoming crazed from within. I didn't think the paint would last after a few more years of freeze/thaw/UV sunlight.
Old Jan 16, 2011 | 05:49 PM
thewrangler99's Avatar
https://acurazine.com/forums/showthr...t=ebay+pillars
http://cgi.ebay.com/ebaymotors/BLACK...Q5fAccessories
Old Jan 16, 2011 | 05:58 PM
03tLsNBP's Avatar
MechEng
you could try the vinyl that ^ posted or if you dont mind spending a little more, you could go with 3M gloss vinyl.
or you dont mind the matte black look you can do plasti-dip.
orrr if you have the funds you can get a body shop to paint them black. but do not paint them body color if you have anything other than NBP. it will look terrible.
Old Jan 16, 2011 | 06:26 PM
That's why i would get them done in NBP, they are re painting my hood and might test spray on my lip, if they have leftover NBP might as well use that.
Old Jan 16, 2011 | 09:35 PM
KobeAllDay's Avatar
Yo is your plastidip one holding up well? cause i liked the look of that
Old Jan 16, 2011 | 10:40 PM
mine is still holding up and it's gloss black!
Old Jan 16, 2011 | 10:48 PM
03tLsNBP's Avatar
MechEng
its kind of peeling at the edges from a combination of the elements, and going a little too rough with the ice scraper. but in the Spring i am just going to peel it all off and respray it. it is really easy and forgiving stuff to work with.
i heard somewhere that they make a gloss plasti-dip. i havent seen it any stores but maybe they sell it online
Old Jan 17, 2011 | 10:02 AM
KobeAllDay's Avatar
So all you did was remove the pillars, sprayed a good coat on it and let it dry, and your done? if you did remove pillars how did it look?
Old Jan 17, 2011 | 07:21 PM
03tLsNBP's Avatar
MechEng
i didnt take off the pillars. i just wet sanded them down so they were smooth and cleaned them with acetone. any overspray can be peeled/rubbed off with your fingers or a towel.
i sprayed on 2 coats. about 10-15 minutes between coats. thats about it.
Old Jan 18, 2011 | 09:58 AM
Flipster23's Avatar
drive ur car off a cliff
Old Jan 18, 2011 | 06:27 PM
DaveS221's Avatar
^lmaoooo
aite. REAL solution, not hard, clean, permenant. follow the diy to remove ur pillars. go to autozone or auto store and pick up duplicolor trim paint. THEY HAVE HONDA NBP!!!! use high grit sand paper, meaning 400, sand off old shiney coat, take grit up to 600 or even 800 to smooth out. then spray like 5-6 coats of paint, then spray 8-10 coats of clear. give each coat AT LEAST 15mins to dry b4 adding another. this is not hard by any means! only trouble i had was dropping the stupid screws into the door because i am a klutz. result is clean and dam near close to factory look. the only way you would be able to tell is if you had them side by side to compare.
Old Jan 18, 2011 | 06:40 PM
fsttyms1's Avatar
Why would you NOT take the 5 min to take them all off and sand them and paint them OFF the car making a better paint job with NO overspray???????
Old Jan 18, 2011 | 06:41 PM
fsttyms1's Avatar
Originally Posted by DaveS221
^lmaoooo
8-10 coats of clear?????? 3-4 is more than enough
Old Jan 18, 2011 | 06:50 PM
DaveS221's Avatar
^not with the duplicolor. it doesn't make it as shiny as stock.
Mike734
Dec 10, 2021 01:25 PM
mlody
Dec 4, 2019 02:11 PM
LogicWavelength
3G TL Photograph Gallery
33
Nov 1, 2015 09:38 AM
thegipper
Sep 28, 2015 01:01 PM
Matthew Purpura
Sep 25, 2015 06:10 PM
